Local Time 13:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD Card pinout
palcal
Posted: 07:26pm 31 Mar 2024
In the manual on page 17 the pinout is shown and pin 1 is CS however in all the pinouts I can find pin 2 is CS...
So what is the correct pinout. I just had a batch of boards made using Pin 1 for CS as per the manual and I get an error SDCARD not found.
The Pinout in the manual also has Pins 3 and 6 going to ground. I looked at the circuit for the Pico Backpack in Silicon Chip and Pin 2 is CS and there is only one pin going to ground.
Edited 2024-04-01 05:39 by palcal
circuit
Posted: 07:51pm 31 Mar 2024
Does this help?
Your diagram illustrates the pinouts for a micro-SD card; the diagram on page 18 in the Picomite manual is for a standard SD card.
Edited 2024-04-01 05:55 by circuit
Posted: 07:57pm 31 Mar 2024
Post deleted.
Beat me to it!
Edited 2024-04-01 05:59 by Mixtel90
stanleyella
Posted: 08:00pm 31 Mar 2024
page 17 in the manual is connect to sd card direct. different
Posted: 08:05pm 31 Mar 2024
As I said, that's for a full size SD card. A micro SD card is different.
palcal
Posted: 08:38pm 31 Mar 2024
I never gave that a thought, oh well the boards are still useful just not with an sd card. I'll re design the board, not the first time I've got a batch of boards with a mistake.
stanleyella
Posted: 09:10pm 31 Mar 2024
I used the one recommended by Mick
dim problemio ,so nice from price to size.. and just works :)
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16797
palcal
Posted: 11:00pm 31 Mar 2024
Thanks for that, just bought some.
Posted: 03:59am 01 Apr 2024
If it makes you feel any better, I also made the exact same assumption when I first designed a board to us a micro-SD, after having used full-size SD cards for a while, and you know what they say about assumptions.....
But this is the kind of mistake, that you only make once - generally speaking - as your little grey cells will now remind you that they have different pinouts!
Posted: 08:35am 01 Apr 2024
I don't have to think about it too hard now. My SL6 macros have the pin signals on them, not just numbers. :)
Posted: 09:18pm 01 Apr 2024
I must admit, I do the same!
Posted: 10:39pm 01 Apr 2024
Lads,
That is a good idea,  I will have to modify my DEX parts to reflect that as I always do the head scratch every time I use one of them.
Posted: 08:08am 02 Apr 2024
I only put numbers on the unused pins and text on the used ones. The text is too small really, but it doesn't matter if it won't screen print as it's going to be covered up by the socket anyway, usually. The info is only there for me during design. Sometimes I delete it later, sometimes I don't. It doesn't matter once I have the track layout done.
Posted: 08:38am 02 Apr 2024
Of course, if you used EasyEDA you wouldn't have these problems. When you hover over the pin in the layout it gives you the name assigned.
The models in the LCSC part catalogue are in general excellent and by starting from the schematic you know you have got it right every time
Edited 2024-04-02 18:39 by matherp
Posted: 08:55am 02 Apr 2024
Oh yes, I can't argue with that. :)
I've not tried adding my favourite ebay parts to EasyEDA yet...
