Local Time 13:19 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : More than 4 count Inputs with Webmite ?
Gerad
Posted: 10:24pm 28 Mar 2024
Hello Everybody
Is it possible to define more than 4 count inputs with Webmite ?
Gerad
Posted: 10:31pm 28 Mar 2024
Not actual high speed counter inputs, no. If you only need low speed then you can use any pins and use them to trigger interrupts if you like. They are a lot slower though.
Gerad
Posted: 10:45am 29 Mar 2024
Hi Mick
I thought so. Then I probably have to use 2 picomite as count slave controllers for another 8 count inputs.
Thank you very much for your information
Gerad
Posted: 12:43pm 29 Mar 2024
Hi Gerad.
You can use PIO. In the normal pico you have 8 PIO state machines, each can count 1 input. In the VGA pico, you can use only 4 PIO state machines, since the other 4 are used for creating VGA.
And, in case they are slow changing inputs, you can count in MMbasic.
What is your application, What are you counting ?
Edited 2024-03-29 22:43 by Volhout
Gerad
Posted: 03:04pm 29 Mar 2024
Hi Volhout
Unfortunately, I have absolutely no idea how the PIO state machines work
I count pulses from 12 water flow meters. between 90 and 350 impulses/sec each.
Gerad
Posted: 03:32pm 29 Mar 2024
  Quote  I count pulses from 12 water flow meters. between 90 and 350 impulses/sec each.
Assuming these are clean "non-bouncing" 50% duty cycle signals then you could easily do this in a loop with a port function reading the inputs and comparing with the previous reading. You could do this in say a 1mS timer loop which should catch everything.
Something like:
settick 1,readpins
do
'whatever
loop
sub readpins
 a%=port(pin spec)
 new%= (a% XOR last%) and a% 'pins that have changed to ON
 last%=a%
 for i%=0 to nummeters%-1
   if new% and 1 then inc counter%(i%)
   new%=new%>>1
 next i%
end sub
Gerad
Posted: 08:57am 30 Mar 2024
Thanks matherp
for the example. I'm trying to understand it.
It makes me uncomfortable, but I have a small question:
what does “%” mean, e.g. “new%)?
Gerad
Posted: 09:19am 30 Mar 2024
% is the syntax that specifies the variable is an integer - see the manual for more details
%=integer, !=float, $=string
Posted: 09:21am 30 Mar 2024
It makes the variable "new" an integer.
Another way is to use
DIM INTERGER new
then "new" will always be an integer variable, even without the % symbol.
Some people prefer to always use the symbols, others prefer to use DIM to set the type.
This stuff is in the manual, it's just a case of finding it. :) Look under "Variables and expressions". Probably around page 40-ish depending on your manual.
Gerad
Posted: 10:15am 30 Mar 2024
Hello matherp , Hello Mick
many thanks for your help.
I wish you a nice Easter.
Gerad
Posted: 03:49pm 30 Mar 2024
Hi Gerad,
Peter's proposal works, but requires OPTION CPUSPEED 252000 or OPTION CPUSPEED 378000 to manage 12 count inputs in MMBasic. The standard picomite speed of 133000 is not sufficient for 12 inputs.
Below is the program to test this:
 'count events on 12 GPIO pins
 nummeters%=12
 dim counter%(nummeters%-1)
 openpins
 'measurement speed
 settick 1,readpins
 'main loop
 do
   'just simulating all the math for 100ms
   pause 100
   'print how much time the interrupt routine takes (out of 1ms tick)
   'print t
 loop
 'read all the pins
sub readpins
 't=timer
 a%=port(1,2,4,4,9,4,14,2)   'GP0...GP11
 last%=a%
   new%=new%>>1
 next i%
 't=timer-t
end sub
sub openpins
 setpin 1,din
 setpin 2,din
 setpin 4,din
 setpin 5,din
 setpin 6,din
 setpin 7,din
 setpin 9,din
 setpin 10,din
 setpin 11,din
 setpin 12,din
 setpin 14,din
 setpin 15,din
end sub
When you "un-comment" lines 15,20,28  it gives you the time consumed in the interrupt routine. At 252MHz (CPUSPEED 252000) that is 62% (0.62ms of 1ms), and that will be barely enough to run a responsive main program.
Most time is consumed in this section of the interrupt routine 0.5ms of 0.62ms.
   new%=new%>>1
 next i%
Maybe there is a faster way of doing this, that would be good. But I have no alternative yet. Minor speed up can be achieved by
NEXT
in stead of
NEXT i%
And defining nummeters% as 11 (in stead of 12) to ommit the math in the interrupt routine.
in stead of
That would bring you to 0.56ms (from 0.62ms) every 1ms interrupt
EDIT: this brute force interrupt routine is faster (0.44ms)....
sub readpins
 t=timer
 last%=a%
 inc counter%(0),(new% and 1=1)
 inc counter%(1),(new% and 2=2)
 inc counter%(2),(new% and 4=4)
 inc counter%(3),(new% and 8=8)
 inc counter%(4),(new% and 16=16)
 inc counter%(5),(new% and 32=32)
 inc counter%(6),(new% and 64=64)
 inc counter%(7),(new% and 128=128)
 inc counter%(8),(new% and 256=256)
 inc counter%(9),(new% and 512=512)
 inc counter%(10),(new% and 1024=1024)
 inc counter%(11),(new% and 2048=2048)
 t=timer-t
end sub
Edited 2024-03-31 02:22 by Volhout
Posted: 11:01pm 26 Apr 2024
To shave off a few more uS use single character variable names and try to squeeze loops into a single line with minimum white-space. Every character takes time to read.
new% caused an error as New is a keyword, changed to newm%.
  new%=new%>>1
next i%
Becomes
Dim Integer i, m, n, c(nummeters%-1)
m = nummeters%-1 : n = newm%
For i=0To m:If n And 1 Then:Inc c(i):EndIf:n=n>>1:Next
Edit.
If the number of meters is always the same replace the variables nummeters% and 'm' with the number.
Looking up the value of variables / constants takes time.
For i=0To 11:If n And 1 Then:Inc c(i):EndIf:n=n>>1:Next
timer=0:For i=0To 11:If n And 1 Then:Inc c(i):EndIf:n=n>>1:Next:?timer
0.335
> ? mm.info(cpuspeed)
378000000
PS. You can remove the space before 'To' but not the one after it.
Edited 2024-04-27 10:53 by phil99
Posted: 07:44am 27 Apr 2024
INC N,N
is a fair bit faster than
N=N>>1
Edited 2024-04-27 17:46 by matherp
Posted: 07:48am 27 Apr 2024
Hi Phil,
Avoiding the loop is faster. See my post before.
I get 0.44 ms at 252Mhz. That would be 0.29 at 378Mhz.
Gerad
Posted: 07:29pm 01 May 2024
Thank you very much for all the good suggestions and examples.
Gerad
Posted: 07:44pm 01 May 2024
  matherp said  INC N,N
N=N>>1
The point is well made, though I think that would be instead of N=N<<1
