stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807
Posted: 10:47pm 20 Mar 2024
hi. a prob reading the key pressed on vga usb keyboard. mode 1 cls do k = asc(inkey$) print k loop
this prints lots of 0's but not many keypresses even holding the key down.
this code responds to keys and changes which sprite to use for flame animation but remembers last key so if no keys then uses no flame sprite but no key happens all the time even if a key is pressed. do I set auto repeat? no idea.
do k = asc(inkey$) 'if kthen select case k Case 100 'd up spnum=2 gravity=gravity-.35 Case 115 's left spnum=5 inertia=inertia-0.05 Case 102 'f right spnum=6 inertia=inertia+0.05 case 83 'shift s up/right spnum=3 inertia=inertia+0.05 gravity=gravity-.35 case 70 'shift f up/left spnum=4 inertia=inertia-0.05 gravity=gravity-.35 case 0 spnum=1 gravity=0.15 end select 'else 'spnum=1 'gravity=0.15 'endif last_lander_x=lander_x:last_lander_y=lander_y lander_y=lander_y+gravity-antigravity lander_x=lander_x+inertia ' inc fnc: if fnc=20 then fnc=0:fno=not fno'which lander for animation box last_lander_x,last_lander_y,30,39,,0,0 'erase lander if fno=0 then'draw noflame lander sprite WRITE 1,lander_x,lander_y else'draw flame lander sprite WRITE spnum,lander_x,lander_y end if
loop' later
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382
Posted: 11:35pm 20 Mar 2024
Perhaps experiment with this. Processing the key is done in a subroutine. In the event of multiple key presses clear the keyboard buffer before returning to the main program. Something like this at the end of the Sub might work:-
Do : Loop Until Inkey$ = ""
Posted: 12:00am 21 Mar 2024
thanks phil. do[n my brain, knew it wouldn't be as easy as inkey$ but the logic seemed to make sense but no keys is the main output values. I'll go back to my mcp 23017 i2c expander board with 8 buttons. sod compatibility sharing code. no, I'll try interrupts, they can't be difficult.
Posted: 02:52am 21 Mar 2024
Maybe InKey$ can do what you want if you ignore k = 0, ie change Case 0 to Case Else for any key without a Case. See if this is useful.
do k = asc(inkey$) if k then select case k Case 100 'd up spnum=2 gravity=gravity-.35 spnum=5 inertia=inertia-0.05
''' case else spnum=1 gravity=0.15 end select endif ...
loop
Edited 2024-03-21 13:04 by phil99
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11885
Posted: 07:03am 21 Mar 2024
Pico USB versions support the keydown function - see the CMM2 manual for details
Posted: 08:20pm 21 Mar 2024
This doesn't show a key pressed in a prog. ON KEY 100,d_up ON KEY 115,s_left ON KEY 102,f_right ON KEY 83,S_up_left ON KEY 70,F_up_right
sub d_up spnum=2 gravity=gravity-.35 end sub ' sub s_left spnum=5 inertia=inertia-0.05 Do : Loop Until Inkey$ = "" end sub ' sub f_right spnum=6 inertia=inertia+0.05 Do : Loop Until Inkey$ = "" end sub ' sub F_up_right spnum=3 inertia=inertia+0.05 gravity=gravity-.35 Do : Loop Until Inkey$ = "" end sub ' sub S_up_left spnum=4 inertia=inertia-0.05 gravity=gravity-.35 Do : Loop Until Inkey$ = "" end sub '
neither did this except keydown(1)=100 which seemed to be stuck or repeating if keydown(1)=100 then spnum=2:gravity=gravity-.35 else if keydown(1)=115 then spnum=5:inertia=inertia-0.05 else if keydown(1)=102 then spnum=6:inertia=inertia+0.05 else if keydown(1)=83 then spnum=3:inertia=inertia+0.05:gravity=gravity-.35 else if keydown(1)=70 then spnum=4:inertia=inertia-0.05:gravity=gravity-.35 else if keydown(1)=0 then spnum=1:gravity=0.15 end if
