Local Time 19:18 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ARMmite H7 DevEbox board
PhenixRising
Posted: 09:58pm 20 Mar 2024
Can anyone provide me with the exact header spacing please? I have the WeAct version and not sure if the spacing is the same. I loaded the board layout png images and scaled them in Paint.Net but I'd like to know for sure as I'm throwing together a carrier board and won't receive my DevEbox for a while.
disco4now
Posted: 02:31am 21 Mar 2024
The pins on the side J2 and J3 are the same spacing but layout is different, the manual has layouts for both. The SDCard and USB  connector are at different end of the board on the DeveBox. Also its a micro USB. There is also J4  (8 pins) across the end , also J1 (5 pins). The manual shows this. The spacing of these 8 and 5 pin headers in relation to J2 and J3 would need some further analysis if you want these verified.
Gerry.
F4 H7FotSF4xGT
PhenixRising
Posted: 05:54am 21 Mar 2024
Many thanks Gerry
Feeling a bit reassured about WeAct so I think I'll look at two versions of the carrier board, to be covered.
