Local Time 19:18 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [PicoMite] DIR$()  Missing dots
twofingers
Posted: 05:52pm 19 Mar 2024
Hi, I would like to know whether the removal of the "dots" from the Dir$("*",DIR) function is intended in the newer (> 5.07) firmware versions.
'************ testdir$ *********
Print "MMBasic version:" MM.Ver
Print "--------------------------------"
DirName$= Dir$("*", Dir)
Print DirName$
Do While DirName$<>""
   DirName$ = Dir$()
   If DirName$<>"" Then Print DirName$
loop
Output for MMBasic version: 5.0706
nsa
Output for MMBasic version: 5.09
MMBasic version: 5.090006
nsa
What happened to the dots and if so why?
I think this doesn't make Picomites more compatible with other previous MMBasic versions.
Michael
Edited 2024-03-20 03:53 by twofingers
The lone and ...
Posted: 09:06am 20 Mar 2024
FatFS is used for the SDcard system and does not return these when asked to return directories. In order to maintain compatibility between the A: and B: drives I have suppressed them for the "A:" drive. This is inline with other MMbasic variants (just confirmed on CMM2). Earlier versions of the PicoMite firmware were out of line for the A: drive
              if (lfs_info_dir.type & (LFS_TYPE_REG |  LFS_TYPE_DIR) && pattern_matching(pp, lfs_info_dir.name, 0, 0) && !(strcmp(lfs_info_dir.name,".")==0 || strcmp(lfs_info_dir.name,"..")==0 )){
Edited 2024-03-20 19:11 by matherp
twofingers
Posted: 04:53pm 20 Mar 2024
Thank you very much!
It's to bad, I've gotten used to it for 40 years.
For me it was very surprising. I don't have an SD drive on the Picomite and I hadn't noticed it on the CMM2 until now. A note in the manual could be useful.
A workaround should be easy to do.
Michael
The lone and ...
