Local Time 13:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Board makers - give me your options
     Page 1 of 3
Posted: 04:35pm 18 Mar 2024
In the next release of the various Pico firmware versions I'm going to include a new option
OPTION PLATFORM name
This will configure all required options for a board from the basis of the defaults for the relevant variant of the firmware
So:
OPTION PLATFORM CMM1.5
will effectively do the equivalent of:
option reset
option pico off
option heartbeat off
option system i2c gp14,gp15
option sdcard gp13,gp10,gp11,gp12
option vga pins gp23,gp18
option audio gp16,gp17
This sits on top of the PicoMiteVGAUSB firmware defaults which already configure
OPTION SERIAL CONSOLE GP8,GP9
OPTION CPUSPEED 252000
If you would like your board supported in this way please post on this thread
the name you would like - please make this specific rather than a general name that could apply to multiple configurations,
the firmware variant to which your board is targetted,
and the options you want set over and above the defaults for the relevant version of the firmware
This offer only applies to open source PCB designs available to all not one-off breadboard setups.
NB: for Mick - keep the numbers down!!!
Edited 2024-03-19 02:45 by matherp
Posted: 05:08pm 18 Mar 2024
I have reservations Peter.
You already introduced OPTION PLATFORM to just set a string that could be retrieved via MM.INFO$. With what you propose now you can't set that string independently of "messing" with other OPTIONs which will make testing harder and  also challenge those who want to stray from a particular design's default pin assignment.
Perhaps OPTION PLATFORM "foo" could just set the platform constant (as it does now) whereas OPTION CONFIG PLATFORM "foo" could do the full magic you are proposing ... or alternatively since you have overcome the command token limit, perhaps just CONFIGURE [AS] "foo".
Edited 2024-03-19 03:15 by thwill
Posted: 05:17pm 18 Mar 2024
Hehe...  I'm going to have to think hard about this one!  :)
I assume that if OPTION PLATFORM isn't used the OPTIONS are set individually as usual.
This one doesn't support USB.
OPTION PLATFORM VGA BASIC
option reset
option vga pins GP16, GP18
option sdcard GP14,  GP13, GP15, GP12
option audio GP6, GP7
option system i2c GP26, GP27
These do support USB
OPTION PLATFORM PICOGAME 4
option reset
option vga pins GP10, GP4
option system i2c GP12, GP13
option sdcard GP27, GP15, GP28, GP14
option audio VS1053 GP18, GP19, GP20, GP17, GP21, GP22, GP16
OPTION PLATFORM PICOGAME 4-PWM
option reset
option audio GP18, GP19
I'm not sure if any of the others are worth doing. Most are a bit specialised or outdated really.
EDIT:  Good point, Tom.
Edited 2024-03-19 03:20 by Mixtel90
Posted: 06:00pm 18 Mar 2024
  Quote  You already introduced OPTION PLATFORM to just set a string that could be retrieved via MM.INFO$.
Forget the name - could be anything
OPTION PCB, OPTION BOARD or whatever
and, of course you can ignore it or use it then unset/change things as you wish
Edited 2024-03-19 04:02 by matherp
Posted: 06:55pm 18 Mar 2024
Here are my 5 cents...
OPTION BOARD VGAMite (your design 1.4 and 1.7)
OPTION SYSTEM I2C GP14,GP15
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION SDCARD GP13, GP10, GP11, GP12
OPTION AUDIO GP6,GP7'
OPTION BOARD GEEK
OPTION SYSTEM SPI GP10,GP11,GP24
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION LCDPANEL ST7789_135, LANDSCAPE,GP8,GP12,GP9,GP25
OPTION SDCARD GP23, GP18, GP19, GP20
1/I love it when OPTIONS are pre-configured, but they should be upgradable (and that may not as easy as it sounds).
i.e. OPTION KEYBOARD US should be upgradable to OPTION KEYBOARD US,0,1,0,0 without having to enter all options.
2/ I would love it when disabling options would always use the same keyword. i.e all options would be disabled with OPTION xxx RESET. Historically there have been various keywords to disable options.
Regardless, I love the idea of setting various options with one board definition.
Edited 2024-03-19 05:01 by Volhout
Posted: 07:24pm 18 Mar 2024
Let's not add BOARD and PCB to the mix, it's confusing enough with DEVICE and PLATFORM; and before anyone says "But Tom, you asked for PLATFORM", I didn't, I was happily using an "A:/.config" file .
If you don't want to add a new CONFIGURE command then I suggest overloading OPTION LOAD so that some names are (case-insensitively) recognised as "special" whilst unrecognised ones are treated as filenames.
Edited 2024-03-19 05:38 by thwill
Amnesie
Posted: 09:02pm 18 Mar 2024
Hmmm...
I rather like to enter all options by hand. This way I have full control for all my own PicoMite interations.
I mean how often do you really change the options? Okay.. some after firmware update.
On the other hand, it is good for anyone whos new to the Mite-Family and don't want to look up all those specified options for this individual board. I think as long as one can enter these options manually too, it's a nice addition.
Greetings
Daniel
Posted: 09:55pm 18 Mar 2024
A similar idea would be for board designers to publish a BOARD_XXX.OPT file with their designs.
The length of .OPT files is Xmodem compatible so is easy to transfer to A: after the .UF2.
Edit. Or more than 1 .opt if several configurations are possible on that board.
Edited 2024-03-19 07:57 by phil99
karlelch
Posted: 10:17pm 18 Mar 2024
I‘d also vote for a config file on A: that is automatically loaded on boot. If that could be edited using the build in editor, that would give full control.
It could be combined with the idea with which Peter started this thread: setting the board/pcb/contraption option could automatically create a default config file.
Thomas
Posted: 10:55pm 18 Mar 2024
We've been here before. The .opt file format isn't stable enough over firmware changes to be used in this way and there are some options that need to be known before the PicoMite gets to the point it can read from A:/
FWIW I think Peter's idea is an improvement provided it doesn't break the existing "PLATFORM as an independent string property" behaviour but my preference given the known limitations would be to have the ability to use a human readable .opt file that has to be explicitly OPTION LOADed.
YMMV,
Edited 2024-03-19 08:56 by thwill
EDNEDN
Posted: 11:10pm 18 Mar 2024
  karlelch said  Hi,
This is a good idea.   It probably warrants a full discussion of the benefits and drawbacks.    I especially like the idea of a default config file being automatically populated.
Edited 2024-03-19 09:11 by EDNEDN
Posted: 12:00am 19 Mar 2024
  Quote  there are some options that need to be known before the PicoMite gets to the point it can read from A:/
Have not tried the latest Betas, has the automatic creation of A: been removed?
In any case if the .OPT format changes the idea of using .OPT files is dead, though so far I haven't had a problem using them after upgrading firmware.
Posted: 01:57am 19 Mar 2024
the idea of a plain-text .opt (or .cfg) file stored on A: has been raised in the past, more than once. this would remove the conundrum of the file being in a format that changed between versions, as well as allowing said file to be edited using mmbasic's inbuilt editor. the .cfg file would then replace all persistent options from the perspective of the user, being read in and acted upon automatically when mmbasic starts up.
unfortunately, Peter dismissed the idea as being too complicated for him to be able to implement.
i fear that now at the moment we are heading down the slippery slope of over-configurability. but with the "picomite VGA+USB" variant at least, we can guarantee that mmbasic has access to a (USB) keyboard for input. if the existing standardized use of GP16-21 for VGA output is fixed in stone, then we also have guarantee VGA output. given these two, the user will always have access to an A:OPTIONS.CFG file.
remember, with the MX170 et al Geoff fixed various pin configurations, and nobody suffered excessive hardship as a result.
rob   :-)
Edited 2024-03-19 12:11 by robert.rozee
Malibu
Posted: 05:04am 19 Mar 2024
My 2-bob's worth... and I'm just a casual user on any of the mite variants.
Any improvement is usually an improvement, so if you want to go down the "easy to configure" path, why not, if it makes life easy for majority of people
I'm not sure I'd use it because I rarely enter any OPTION commands... first time in setting up for sure, but after that - it stays like that until I do an O/S upgrade, or some other radical design change. (Rarely)
I could see it being a benefit to anyone that chops and changes regularly, but for long term working on a project, where's the saving? (Apart from a few minutes in setting initial OPTIONs)
Besides, I like full control in set-ups, so I'm happy to do it all manually.
If you're open to other suggestions for future functions in the language, I've got a few that I could toss into the cauldron that may end up with a better O/S (Don't want to hijack the thread and go off-topic here...)
Frank N. Furter
Posted: 08:09am 19 Mar 2024
Peter, these are the settings for my tiny "DREAMCOMPUTER":
> option list
PicoMite MMBasic USB Edition  5.09.00b7
OPTION SYSTEM I2C GP6,GP7
OPTION KEYBOARD GR, 0, 0, 600, 150
OPTION CPUSPEED  252000 'KHz
OPTION LCDPANEL CONSOLE 7
OPTION DISPLAY 40, 80
OPTION LCDPANEL ILI9488, LANDSCAPE,GP15,GP14,GP13,GP2
OPTION TOUCH GP12,GP11,GP10
GUI CALIBRATE 0, 3969, 3900, -1228, -848
OPTION SDCARD GP22
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
OPTION RTC AUTO ENABLE
OPTION DEFAULT FONT 7, 1
Posted: 08:54am 19 Mar 2024
God, you try and make things easier and people wade in trying to make fundamental changes
Let me explain how options work:
When you set an option it writes the value to an area of flash memory and then reboots. The first thing the firmware does on startup is to read that area of memory to configure itself. This sets things like clocks and pin usage. Without a significant re-write, which isn't going to happen, it isn't possible to read in options in whatever format from the A: drive as part of the bootup sequence. I re-iterate, OPTIONS ARE SET BEFORE TRIGGERING A REBOOT.
Remember also, that an option like setting the modbuffer kills the A: drive
Also, do you really want to brick your device requiring a complete nuke by mistyping an option in an ascii file? Is anyone volunteering to write a fully comprehensive option parser and checker to ensure this doesn't happen?
I don't care what the format of any new command is. If Tom prefers a new command "CONFIGURE" and that is OK with most people then that is fine but the basic concept I propose is how it is going to work (or not if I don't implement it).
Posted: 08:55am 19 Mar 2024
One problem with an options file in flash memory is it's erased on a re-flash of MMBasic.
A short command that auto-configures looks good, especially if LIST options (at any time, quite possibly weeks later) shows what happened - quick way to see which pins are used/set for what.
Posted: 09:22am 19 Mar 2024
  matherp said  God, you try and make things easier and people wade in trying to make fundamental changes
Everyone has to have a hobby , but seriously though I think you are making a rod for your own back with this change, for a start as you've already observed the only thing that happens faster than you adding features is (UK) Mick designing PicoMite PCBs.
  matherp said  Is anyone volunteering to write a fully comprehensive option parser and checker to ensure this doesn't happen?
Ask a silly question, here you go, though it probably won't do you much good as it is for MMB4L:
   https://github.com/thwill1000/mmb4l/blob/main/src/common/options.h
   https://github.com/thwill1000/mmb4l/blob/main/src/common/options.c
Note that I don't expect you to incorporate this, I'm just showing off  .
  matherp said  I don't care what the format of any new command is. If Tom prefers a new command "CONFIGURE" and that is OK with most people then that is fine but the basic concept I propose is how it is going to work (or not if I don't implement it).
In the language of requirements engineering, in my opinion:
It MUST still be possible to set the existing PLATFORM option without that affecting any other options.
A command OPTION foo blah blah blah SHOULD manipulate only option "foo" and not any other option (existing OPTION DISK LOAD/SAVE, etc. excluded).
My view, having slept upon it and reviewed the existing OPTION syntax is that you should consider overloading OPTION RESET:
OPTION RESET [, <board>]
And that <board> should be case-insensitive.
YMMV,
Posted: 09:42am 19 Mar 2024
  Quote  My view, having slept upon it and reviewed the existing OPTION syntax is that you should consider overloading OPTION RESET:
Yes, I like that (no comma)
Posted: 09:51am 19 Mar 2024
  matherp said  Yes, I like that (no comma)
Excellent!
This is what the configuration for the classic Game*Mite would look like:
OPTION PLATFORM "Game*Mite"
OPTION SYSTEM SPI GP6,GP3,GP4
OPTION LCDPANEL ILI9341,RLANDSCAPE,GP2,GP1,GP0
OPTION TOUCH GP5,GP7
OPTION SDCARD GP22
OPTION AUDIO GP20,GP21
OPTION MODBUFF ENABLE 192
It also has OPTION AUTORUN 1,NORESET ... but does that make sense until after the splash program (FLASH 1) has been loaded ?
Edited 2024-03-19 19:52 by thwill
     Page 1 of 3
