Local Time 14:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : True/False conflict using INV?
PhenixRising
Posted: 09:19am 11 Mar 2024
Manual:
The other logical operations result in the integer 0 (zero) for false and 1 for true
But:
Print inv 1
The result is -2
Print inv -1
The result is 0
Posted: 09:31am 11 Mar 2024
I'm braced to be told that I am talking out of my arse but INV isn't a logical operation (you might be looking for NOT), it's a bit operation.
> ? Bin$(1, 64)
0000000000000000000000000000000000000000000000000000000000000001
> ? &b1111111111111111111111111111111111111111111111111111111111111110
-2
> ? Bin$(-1, 64)
1111111111111111111111111111111111111111111111111111111111111111
> ? &b0000000000000000000000000000000000000000000000000000000000000000
0
PhenixRising
Posted: 09:54am 11 Mar 2024
  thwill said  I'm braced to be told that I am talking out of my arse but INV isn't a logical operation (you might be looking for NOT), it's a bit operation.
> ? Bin$(1, 64)
-2
> ? Bin$(-1, 64)
0
Thanks Tom. I do use NOT but I tested INV without consulting the manual
Posted: 10:24am 11 Mar 2024
from page 27 of the User Manual, MMBasic Ver 5.08.00, Revision 4:
  Quote  NOT INV
invert the logical value on the right (e.g. NOT a=b is a<>b) or bitwise inversion of the value on the right (e.g. a = INV b)
what is interesting is that the above example from the user manual "NOT a=b is a<>b" is wrong:
> a=5
> b=6
> ? a<>b
1
> ? not a=b      ' interpreted as (not a)=b
0
> ? not (a=b)    ' interpreted correctly with brackets
1
the priority of both NOT and INV are higher than that of = and <>. this is a good example of why unary operators (which are really just a sub-class of functions) should always have their parameter enclosed in brackets to prevent confusion!
now, as for functions, they present an extra level of mayhem:
> sin=12
> ? sin 34
12 34
> ? sin(34)
0.5290826861
clearly the mmbasic interpreter is expecting the function's parameter to be enclosed in brackets, but behaves badly if none are present. questions - should it be legal to have a variable with the same name as a function? should it be made mandatory to enclose the parameter lists for functions and unary operators in brackets?
rob   :-)
Posted: 10:50am 11 Mar 2024
If it's meant to be as if
not (a=b)
then the manual could do with a fix - good find if so.
Posted: 11:06am 11 Mar 2024
hi John,
   i think in the first instance it is an error in the manual, although one that illustrates a classic programming mistake.
a further test:
> x=sin 34
Error: Expression syntax
> x=sin (34)
> ? x
0.5290826861
reveals brackets around function parameters are already mandatory, and that the error here is in allowing function names to be used as variable names. so something like ? sin should give a syntax error, as should sin=1.
the question of how to handle unary operators remains open; i suspect the failure goes way back to when BASIC was first created some 60 years ago. personally, i'd like to see INV, NOT, and - (the last being negation) required to have mandatory brackets around the parameter.
rob   :-)
Edited 2024-03-11 21:07 by robert.rozee
twofingers
Posted: 11:28am 11 Mar 2024
  robert.rozee said  ... the question of how to handle unary operators remains open; i suspect the failure goes way back to when BASIC was first created some 60 years ago. personally, i'd like to see INV, NOT, and - (the last being negation) required to have mandatory brackets around the parameter. [...]
I don't see the problem.
The MMbasic manual says on page 45:
  Quote  ... For normal use of NOT or INV the expression to be operated on should be placed in brackets. Eg:
IF NOT (A = 3 OR A = 8) THEN ...
Michael
Posted: 01:04pm 11 Mar 2024
  robert.rozee said  the above example from the user manual "NOT a=b is a<>b" is wrong
Well spotted, thanks Rob.
  robert.rozee said  unary operators ... should always have their parameter enclosed in brackets to prevent confusion!
NOT does not need to be followed by brackets (for example,  NOT PIN(xx)) and Microsoft (in their wisdom) did not require brackets.  I understand your point but doing ast you say would cause greater problems.
  robert.rozee said  should it be legal to have a variable with the same name as a function?
It is not legal for variables to use a function name.  The fault is that MMBasic does not have a sufficiently sophisticated error detecting mechanism to detect this... it just stumbles on as best as it can.
stanleyella
Posted: 02:00pm 11 Mar 2024
this toggles fno 1 or 0.
inc fnc: if fnc=5 then fnc=0:fno=not fno 'in wisdom no endif needed
if fno=0 then
else
Edited 2024-03-12 01:45 by stanleyella
