Local Time 14:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sync-ing multiple identical mites?
PhenixRising
Posted: 08:43pm 10 Mar 2024
Thinking out-loud here because I'm away from my scope.
Let's say I want to sync two ARMmite H7s for up to a minute at a time, using an external signal.
I could poll an input in a do-loop but would PAUSE with an input interrupt be tighter?
Thinking that the interrupt routine would set TIMER=0 which would then be the reference in each H7.
Incidentally, the manual states that an interrupt response is ~15µsec but wouldn't this be processor & speed dependent?
PhenixRising
Posted: 08:56pm 10 Mar 2024
Orrrrrrrr
Use a PWM from H7#1 to feed an interrupt input on H7#1, H7#2, H7#3, etc?
Posted: 09:02pm 10 Mar 2024
Hi Phoenix,
Assigning an interrupt to an I/O pin is probably the best you can do.
You could opt to generate the sync signal external, or from a hardware block like a RTC or PWM pin.
PhenixRising
Posted: 09:22pm 10 Mar 2024
Thanks Harm, thinking same
Would be cool if it were possible to sync the timers that control SETTICK.
Another question; just reading the manual and trying to understand BITBANG (very cool) but is this a blocking function or background?
