Local Time 14:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SPI SETPIN Error
wolfme
Posted: 10:47pm 09 Mar 2024
if i run the SPI commands
SETPIN GP4, GP3, GP2, SPI
as in the example on page 133 of the manual on a picomite vga, i get error: SPI in use for SYSTEM SPI
This happens for all other SPI or SPI2 pins, too.
What do i wrong?
Posted: 11:57pm 09 Mar 2024
Hi wolfme,
You probably have an option set for system SPI (maybe for a TFT screen)
In that case you can still use the SPI but no need to do the SETPIN again.
I know this is the case for I2C so I would assume it’s the same for SPI.
Kind Regards,
Posted: 02:43am 10 Mar 2024
As Mick wrote, check if System SPI is on SPI1 or SPI2 then you can separately set the other one without error. SPI1 is just called SPI for consistency with other systems.
System SPI is called System SPI regardless of whether it uses SPI1 or SPI2 pins, so you need to check the pin allocation diagram in the PicoMite Hardware chapter.
> option list
PicoMite MMBasic Version 5.09.00b6
OPTION SYSTEM SPI GP18,GP19,GP16 '<--System SPI is on SPI1
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION CPUSPEED  378000 'KHz
OPTION DISPLAY 55, 128
OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13
OPTION TOUCH GP12,GP11
GUI CALIBRATE 0, 3923, 3867, -881, -649
OPTION SDCARD GP17
> SETPIN GP26, GP27, GP28, SPI2 '<--Clk, Tx, Rx - Can be set without error.
Search the manual for System SPI for more info.
Edited 2024-03-10 13:23 by phil99
wolfme
Posted: 07:52am 10 Mar 2024
Thanks for the answers.
Here ist my option list:
> option list
PicoMiteVGA MMBasic Version 5.08.00
OPTION SYSTEM I2C GP14,GP15
OPTION KEYBOARD GR
OPTION PICO OFF
OPTION CPUSPEED (KHz) 252000
OPTION SDCARD GP13, GP10, GP11, GP12
OPTION AUDIO SPI GP24,GP22,GP23', ON PWM CHANNEL 3
OPTION RTC AUTO ENABLE
There's no SYSTEM SPI Set.
I'm using a VGA version on Peter's PCB V1.1a design.
Posted: 08:04am 10 Mar 2024
One spi channel is used by the audio the other by the sdcard - nothing left
wolfme
Posted: 08:41am 10 Mar 2024
  matherp said  One spi channel is used by the audio the other by the sdcard - nothing left
Oh, ok, Thanks.
Posted: 11:24am 10 Mar 2024
Sd card uses SPI hardware? I was under the impression that SD card was bit-banged. Maybe it was in the past.
Volhout.
Posted: 01:05pm 10 Mar 2024
So (if I understand correctly), to use SPI2 for other SPI devices, first:
OPTION SYSTEM SPI GP10, GP11, GP12
OPTION SDCARD GP13
Then you can use SPI2 READ and SPI2 WRITE (SPI2 because GP10/11/12 are SPI1, not SPI0).
You must handle chip select in code.
Edited 2024-03-10 23:07 by lizby
Posted: 02:31pm 10 Mar 2024
If you specify spi pins for the SDcard then the firmware will assume it can use SPI and lock that spi channel. Option System SPI is only relevant to non-VGA versions and in that case the SPI channel can also be used for touch and LCD panel but nothing else.
Posted: 03:27pm 10 Mar 2024
  matherp said  If you specify spi pins for the SDcard then the firmware will assume it can use SPI and lock that spi channel.
Does this imply that if you specify non-spi pins, the SD card will be bit-banged, and then SPI will be available for other uses? E.g., GP20, 21, and 22?
Maybe the broader question is: Is there a way to use audio and LCD with touch and SD card and another SPI device? Or must another SPI device be bit-banged on another set of pins?
Posted: 03:48pm 10 Mar 2024
  Quote  Does this imply that if you specify non-spi pins, the SD card will be bit-banged, and then SPI will be available for other uses? E.g., GP20, 21, and 22?
Yes
Posted: 06:19pm 10 Mar 2024
Yes
which is only half the answer.
  Quote  OPTION SYSTEM SPI CLKpin, MOSIpin, MISOpin
Specify or disable the SPI port and pins for use by system devices (SD Card, LCD panel, etc).
The PicoMite uses a specific hardware SPI port for system devices, leaving the other for the user. This command specifies which pins are to be used, and hence which of the SPI ports is to be used. The pins allocated to the SYSTEM SPI will not be available to other MMBasic commands.
OPTION SDCARD CSpin [,CLKpin, MOSIpin, MISOpin]
Specify or disable the I/O pins to use for the SD Card interface. If the optional pins are not specified the SD Card will use the pins specified by OPTION SYSTEM SPI.
Note: The pins specified by OPTION SYSTEM SPI must be a valid set of hardware SPI pins (SPI or SPI2), however, the pins specified by OPTION SDCARD can be any pins. The pins specified by OPTION SYSTEM SPI and OPTION SDCARD cannot be the same.
as i recall, Peter attempted to use hardware SPI to access the SD card, but was unable to get it working reliably. so he implemented access in software (bitbanged) instead. i believe this is still the case - Peter will need to confirm - and so if OPTION SYSTEM SPI CLKpin, MOSIpin, MISOpin and OPTION SDCARD CSpin are set, then hardware SPI on the selected pins is disabled during SD card access (access bitbanged instead), but enabled during LCD, touch panel, etc access to maximize graphic speed.
Peter - can you please confirm this, preferably with more than a one word sentence?
rob   :-)
