Local Time 14:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Integer divison (MMB4W)
PEnthymeme
Posted: 01:33pm 08 Mar 2024
Hi
I am looking at integer division.
timer = 0
'use integer division
for x = 0 to 1000000
  div= 35\11
next x
print timer,div
timer = 0
'use "normal" division and call integer function
  div= int(35/11)
next x
print timer,div
Output:  Integer division:  332ms
        int() function:    453ms
The former (\ integer division) is roughly 20% quicker.  Now "intellectually" not surprised as this is how I would do it in Python as its the way I was taught - but never really thought why this is the case.   Naively I just assumed that internally division was taking place, and then internally calling the int() function.  Not the case.
Even if I force "div" to be an integer with dim div as integer, the difference persists. (again, not surprised)
"Internally" what is "\" doing that renders it so much quicker than int() and / ?
Px
Posted: 01:50pm 08 Mar 2024
Hi Px,
This is completely as expected.
The integer division is a single instruction
Taking the integer value (instruction 1) of a division (instruction 2) are 2 instructions.
Appart from the math that has to be performed under water, the parser has to lookup the  instructions before it can execute them.
Would this be a compiler language, then the compiled could could potentially be equally  fast.
PEnthymeme
Posted: 02:04pm 08 Mar 2024
  Volhout said  Hi Px,
Cheers - yes, I see how the second requires more calls / instructions - but in my naivety sort of assumed that the first would just be a wrapper to the second.  Not that the first would implement things differently.  But I get it.  As said, my naivety.
Appreciate the feedback.
And for clarity - just asking, not moaning
Px
Posted: 02:07pm 08 Mar 2024
... also
/ is a floating divide, so your integers will be cast as floats for the / to take place
you can see this from the below
> dim integer p,n
> p=35
> n=11
> ?p/n
3.18182
you get a float type answer, not the integer (3) you were expecting
Edited 2024-03-09 00:10 by CaptainBoing
PEnthymeme
Posted: 02:08pm 08 Mar 2024
  CaptainBoing said  ... also
/ is a floating divide, so your integers will be promoted to floats for the / to take place
> dim integer p,n
> p=35
> n=11
> ?p/n
3.18182
Perfect -- didn't appreciate that nuance.
Px
