Local Time 20:04 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pointer to the conversation about the LINE bug
Posted: 09:58am 28 Feb 2024
Hi folks,
Apologies but can someone point me at the original conversation/thread describing the LINE / integer array bug that Peter has just fixed. I need to copy Peter's fix into MMB4L but want a test program first.
Posted: 10:54am 28 Feb 2024
hi Tom,
   you are probably looking for this posting:
https://www.thebackshed.com/forum/ViewTopic.php?TID=16657&P=4#218184
it starts on page 4 of the thread titled "PicoMite USB betas"
rob   :-)
Edited 2024-02-28 20:56 by robert.rozee
Posted: 11:07am 28 Feb 2024
Thanks Rob.
Posted: 11:43am 28 Feb 2024
You probably won't see the problem. I introduced it in 5.08 when I was doing the big tidy up of parsing arrays used as parameters in drawing statements. Actually, I can't see what the bug was in my code. The fix was just to revert the function getargaddress  to a previous working version
Posted: 12:05pm 28 Feb 2024
  matherp said  Tom
Thanks Peter, but I only copied the implementation of LINE from the PicoMite two days ago so I suspect the issue is present.
Posted: 12:15pm 28 Feb 2024
This is a quick way to test it
  Quote  A minimal command line version.
> dim x%(3)=(30,90,90,30), y%(3)=(30,30,90,90)
> Line x%(0),y%(0),x%(1),y%(1)
Draws 3 sides of a square but the 4th finishes at (0,0)
Edit.
Just found an odd thing. It only happens if "%" is used.
Dim Integer ... works properly.
Edited 2024-02-28 22:26 by phil99
Posted: 06:51pm 02 Mar 2024
  matherp said  Actually, I can't see what the bug was in my code. The fix was just to revert the function getargaddress  to a previous working version
In the un-reverted code where the integer and float arrays were using the same path you were skipping a potential "!" at the end of a variable name but not a potential "%" character, change this:
do {
   p++;
} while (isnamechar(*p));
if (*p == '!') p++;
if (*p == '(') {
   p++;
   skipspace(p);
   if (*p != ')') {  // array element
       *n = 1;
       return;
to this:
do {
   p++;
if (*p == '!' || *p == '%') p++;  // <--------- changed line
if (*p == '(') {
   p++;
   skipspace(p);
       *n = 1;
       return;
  phil99 said  Just found an odd thing. It only happens if "%" is used.
As it happens, not an odd thing, the whole problem is that Peter's refactoring introduced a bug where the potential "%" is not skipped.
Edited 2024-03-03 04:52 by thwill
Posted: 07:04pm 02 Mar 2024
  Quote  change this:
  Quote  to this:
thanks
