Local Time 19:50 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with Notepad++ please....
Posted: 11:24pm 26 Feb 2024
I'm trying to use Notepad++ to search a large text file, for a keyword.
I've worked out how to do that, but I can't work out how to COPY all those results either to another file, or to the clipboard so I can paste it into another application.
I ONLY want the lines in the text file, with that keyword in it, and I want to totally ignore all the other lines.
I can get Notepad++ to show me what I want on the screen using SEARCH/Incremental Search, and then put my keyword in the FIND box.
I end up with 1,703 matches - how do I copy those matches and ONLY those matches to another file or the clipboard?
If I try the obvious, and right-click/copy, it only copies that one line the mouse was on.  If I try CTRL-A, it just copies the entire file as you might expect.
I want to copy ONLY the results of the search.  Does anyone know how to do that?
Posted: 11:36pm 26 Feb 2024
Nevermind - worked it out.
EDIT: SEARCH/FIND..., type in my keyword, click FIND ALL IN CURRENT DOCUMENT.  A small window opens up with all the results, CTRL-A select all, right-click/COPY - done.
Edited 2024-02-27 09:38 by Grogster
PhenixRising
Posted: 11:37pm 26 Feb 2024
I was just about to hit the sack so I'm not sure if this is what you need.
Posted: 08:27am 27 Feb 2024
Ah, Notepad++ - the vi of the Windows world. :)
(well, maybe not that bad...)
aFox
Posted: 12:37pm 27 Feb 2024
  Grogster said  Nevermind - worked it out.
Tanks
Very helpful hint. Works like the *nix command grep.
Gregor
Posted: 10:23pm 28 Feb 2024
I used grepwin last time and I still had it on my machine, but I could not remember how to make it give me the results in a separate file either!
I tried NP++, cos I remember someone saying that it could do that job also.
All just a matter of working out how to drive software X!
panky
Posted: 12:33am 29 Feb 2024
@Grogster
You could do it simply from a terminal on your mint system like so
cat 'your_file_to_be_scanned' | grep 'search_string' | tee result.txt
This will print all lines from the source file that contain the search string to the terminal screen and to a file called result.txt
It will overwrite anything already in result.txt unless you add -a after the tee command.
Doug.
Posted: 01:59am 29 Feb 2024
