Local Time 20:04 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sprites and artifacts - same layer
MarkF
Posted: 06:52am 26 Feb 2024
Hi. I am using the PicoMite VGA.
I have two (2) sprites on the same layer.
If I code several movements to the x position of one of the sprites to move it over then leave the 2nd sprite, artifacts are left behind.
What would be the best way to fix this please?
1) Use a special combination of sprite show and hide?
2) Maybe mix in sprite show safe and/or sprite hide safe?
3) Put the sprites on separate layers? But then I'm limited to 10 layers / sprites.
Posted: 07:07am 26 Feb 2024
Hi Mark,
Your explanation is quite clear, but it would help to see the code that shows the artefact, so we can pinpoint where the changeneeds to be made.
But in General:
framebuffer create
framebuffer write f
'default starting point
sprite show 2
sprite show 1
 hide sprite 1
 hide sprite 2 'order of sprites is inportant
 calculate new sprite positions
 show sprite 2
 show sprite 1
 framebuffer copy f,n
 pause 100 'to slow down...
loop
Edited 2024-02-26 17:12 by Volhout
MarkF
Posted: 07:20am 26 Feb 2024
Awesome! Many thanks Volhout.
Edited 2024-02-26 17:43 by MarkF
LeoNicolas
Posted: 04:52pm 26 Feb 2024
I recommend you use sprite next and sprite move to execute the sprite movement in batch.
You can leave sprite show safe and sprite hide safe only to the moment you need to hide and show them.
In Knightmare, I'm also using two buffers, one for the background and another for the sprites.
MarkF
Posted: 09:16am 27 Feb 2024
Hey Leo. Thanks for the Sprite commands recommendations.
I don't know if Sprite next and Sprite move restore the background when they are moved.
I haven't tried a test to see if the bottom layers (background) are restored or not.
LeoNicolas
Posted: 03:24pm 27 Feb 2024
They do it. I have forgotten to mention, the sprites layers do not define the sprites order, it is used for collision detection.
