Local Time 20:05 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Loading data into a multidimension array
PEnthymeme
Posted: 04:12pm 25 Feb 2024
I am looking to load values into an 8,3 array...
And my initial attempt is below (which I know doesn't work ;-) )
DIM WIN_PATTERNS(8, 3)
WIN_PATTERNS = ((1, 2, 3), (4, 5, 6), (7, 8, 9), (1, 4, 7), (2, 5, 8), (3, 6, 9), (1, 5, 9),(3, 5, 7))
I could break the WIN_PATTERNS into a data statement and read into the array for example:
DATA 1, 2, 3, 4, 5, 6, 7, 8, 9, 1, 4, 7, 2, 5, 8, 3, 6, 9, 1, 5, 9,3, 5, 7
and iterate over the arrays.
No problems there.
But, is there a way of loading this into the array directly?
P
Posted: 04:26pm 25 Feb 2024
Try
DIM WIN_PATTERNS(7,2)= (1,2,3,4,5,6,7,8,9,1,4,7,2,5,8,3,6,9,1,5,9,3,5,7)
for i=0 to 2:for j=0 to 7:?WIN_PATTERNS(j,i):next j:next i
stanleyella
Posted: 04:37pm 25 Feb 2024
DIM WIN_PATTERNS(8, 3),a,b,v
restore
for a=0 to 7
 for b=0 to 2
   read v:WIN_PATTERNS(a, b)=v
 next b
next a
for a=0 to 7
 for b=0 to 2
   print WIN_PATTERNS(a, b)
 next b
next a
end
PEnthymeme
Posted: 04:43pm 25 Feb 2024
  lizby said  Try
Thanks - loads ;-)
Not sure my thinking is correct here.
I am trying to code a basic tic-tac-toe.   I was looking to create an array of arrays (which I don't think I can do).
For example WINNING_PATTERN (1) = "1,4,7"  corresponding to the left most column.  In total there are 8 possible winning patterns.
I think I'll refactor it all and store PLAYER_X as PLAYER_X(8) - where this is intially all zero, and as a player selects a square, that square is added to the array.
Assume the board is;
1 2 3
4 5 6
7 8 9
Player selects 4.  So PLAYER_X(3) = 1 and the PLAYER_X array is 0,0,0,1,0,0,0,0,0
I can then check PLAYER_X(0), PLAYER_X(3) and PLAYER_X(7) to see if they are "1"
I might be going down a rabbit hole though.
Px
Posted: 04:47pm 25 Feb 2024
  PEnthymeme said  I was looking to create an array of arrays (which I don't think I can do).
Isn't a 2-dimensional array an "array of arrays"? And by extension more dimensions would be arrays of arrays?
LeoNicolas
Posted: 04:54pm 25 Feb 2024
This is cool. Are you implementing the mini-max algorithm for the game AI?
I have implemented it multiple times in different languages, but never in Basic. I'm curious to know how it will be implemented
PEnthymeme
Posted: 04:55pm 25 Feb 2024
What I think is going on here is my "Python" head getting in the way.
What I was originally think about was:
WINNING_PATTERN = ((1,4,6), (2,5,8)....)  etc
So that I could access WINNING_PATTERNS(0) and get the array (1,4,6)  - Python-list esque.
I could make WINNING_PATTERNS(0) = 146  as a single entry and match the value.
P
PEnthymeme
Posted: 04:58pm 25 Feb 2024
  LeoNicolas said  This is cool. Are you implementing the mini-max algorithm for the game AI?
At this point no.
The "AI" (laughingly called at this point) always follows the route:
5 (try the center first), 1, 3, 9,7 (corners clockwise), 2, 6, 8, 4  - if it finds and "empty" spot it goes there.
And in "text" mode as I like the 1980's Terminal style....
P
Edited 2024-02-26 03:00 by PEnthymeme
PEnthymeme
Posted: 06:03pm 25 Feb 2024
Dirty code - it works, but no "error" checking.
FWIW - MMBASIC - Windows -- but nothing "clever" so probably works on VGA etc
OPTION BASE 1
' Display the game title
PRINT TAB(30); "TIC-TAC-TOE"
PRINT TAB(15); " "
PRINT: PRINT: PRINT
' Initialize the game board and the optimal moves sequence
DIM S(9)
DIM MOVES(9) = (5, 1, 3, 7, 9, 2, 4, 6, 8)
' Ask the player to choose their symbol
INPUT "DO YOU WANT 'X' OR 'O'", PLAYER_CHOICE$
IF PLAYER_CHOICE$ = "X" THEN
   P$ = "X"
   Q$ = "O"
ELSE
   P$ = "O"
   Q$ = "X"
END IF
' Print the current state of the game board
SUB PRINT_BOARD
   PRINT " 1 | 2 | 3 "
   PRINT "---+---+---"
   PRINT " 4 | 5 | 6 "
   PRINT "---+---+---"
   PRINT " 7 | 8 | 9 "
   PRINT
   FOR I = 1 TO 9 STEP 3
       FOR J = 0 TO 2
           CELL = I + J
           ' Determine the mark to print based on the cell's state
           IF S(CELL) = 1 THEN
               MARK$ = " " + P$ + " "
           ELSEIF S(CELL) = -1 THEN
               MARK$ = " " + Q$ + " "
           ELSE
               MARK$ = "   "
           END IF
           ' Print the cell's content
           IF J < 2 THEN
               PRINT MARK$; "|";
           ELSE
               PRINT MARK$
           END IF
       NEXT J
       ' Print the row separator unless it's the last row
       IF I < 7 THEN PRINT "---+---+---"
   NEXT I
   PRINT: PRINT: PRINT
END SUB
' Initialize the winning patterns
DATA 1, 2, 3, 4, 5, 6, 7, 8, 9, 1, 4, 7, 2, 5, 8, 3, 6, 9, 1, 5, 9, 3, 5, 7
FOR I = 1 TO 8
   FOR J = 1 TO 3
       READ WIN_PATTERNS(I, J)
   NEXT J
NEXT I
' Check if there's a win, a draw, or if the game should continue
FUNCTION CHECK_WIN()
   FOR I = 1 TO 8
       ' Check for a winning pattern
       IF S(WIN_PATTERNS(I, 1)) <> 0 AND S(WIN_PATTERNS(I, 1)) = S(WIN_PATTERNS(I, 2)) AND S(WIN_PATTERNS(I, 2)) = S(WIN_PATTERNS(I, 3)) THEN
           CHECK_WIN = S(WIN_PATTERNS(I, 1))
           EXIT FUNCTION
       END IF
   NEXT
   ' Check for any empty cell to continue the game
   FOR J = 1 TO 9
       IF S(J) = 0 THEN
           CHECK_WIN = 2 ' Game continues
           EXIT FUNCTION
       END IF
   NEXT
   ' If no win and no empty cells, it's a draw
   CHECK_WIN = 0
END FUNCTION
' Determine the computer's move based on a predefined sequence
SUB COMPUTER_MOVE
   FOR I = 1 TO 9
       IF S(MOVES(I)) = 0 THEN
           S(MOVES(I)) = -1
           EXIT SUB
       END IF
   NEXT
END SUB
' Main game loop
DO
   ' Print the board and ask for the player's move
   PRINT_BOARD
   DO
       INPUT "WHERE DO YOU MOVE (1-9, 0 to quit): ", M
       IF M = 0 THEN
           PRINT "THANKS FOR THE GAME."
           EXIT DO
       ELSEIF M >= 1 AND M <= 9 AND S(M) = 0 THEN
           S(M) = 1 ' Mark the player's move
           EXIT DO
       ELSE
           PRINT "THAT SQUARE IS OCCUPIED OR INVALID."
       END IF
   LOOP
   ' Check the game state after the player's move
   IF CHECK_WIN() <> 2 THEN EXIT DO
   ' Computer makes its move
   COMPUTER_MOVE
   ' Check the game state after the computer's move
LOOP
' Final board print and game result announcement
PRINT_BOARD
SELECT CASE CHECK_WIN()
   CASE 1
       PRINT "CONGRATULATIONS! YOU WIN!"
   CASE -1
       PRINT "COMPUTER WINS! TRY AGAIN."
   CASE 0
       PRINT "IT'S A DRAW!"
END SELECT
To do:
(1) Error checking
(2) "AI" not based on predetermined moves.
(3) Tidy the screen up
I remember a "StarTrek" game in this manner from a type-in listing from YourSinclair when I was a mere 10-12 year old....
P
Edited 2024-02-26 04:04 by PEnthymeme
