Forum Index : Microcontroller and PC projects : For materp: Raspberry Pi 400
| LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625 |
Probably, it is another dumb question. This idea just came to my mind. How hard is it to port the Mite to a Raspberry Pi 400? It will be awesome to start the Raspberry Pi 400 and see the MMBasic environment It has USB ports, IO ports, HDMI, a keyboard, etc... |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
This would be a dream come true and I was afraid to ask this before... Sadly I think this would be really hard work if even possible at all. So maybe another question for Peter: If not possible to port MMBASIC to the Raspberry Pi, may it be possible to port MMBASIC for Windows to ARM (Raspberry Pi OS)? But yes, Imagine the power of the Raspberry Pi 400 running MMBASIC with GPIO functions or even HDMI... uff a whole new era would rise :D But I am VERY happy with PicoMiteVGA, too :) Greetings Daniel Edited 2024-02-19 08:36 by Amnesie |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11886 |
Ages ago I did a full port of MMbasic to the Pi but every new version of the H/W and every operating system update broke it. I will never touch that cursed device again |
| hitsware2 Guru Joined: 03/08/2019 Location: United StatesPosts: 738 |
How about a version for this ? my site |
| stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807 |
I got a rpi 400. key presses say 3. haven't used it, the keyboard fails it seems. could use a usb or bluetooth but rpi400 is not much use as a pc substitute, too slow,youtube is jerky. I got freebasic working on rpi400 and compiled gcbasic but never messed with wiringpi for fb which would be like mmbasic I guess. fb does sprites I think |
Yes, the keyboard is somewhat flaky. The 4-B with 4G is quite nice. For online use try FydeOS ... my site |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4398 |
Hi, If you are hoping for a bare metal implementation for the Pi then you are out of luck. Of the shedders who like to hear themselves talk only @matherp appears to have anything close to the correct skills and sufficient free-time and he has (IMO sensibly) dismissed the idea. If you are looking for MMBasic as an application then follow my "signature" to MMB4L (MMBasic for Linux) and find the armv6l release of v0.5.0. That should run on the 400. Any developer worth their salt should be able to compile v0.6.0 too, and for ARM64 if they want. Alas no high-res graphics, audio or gpio (except by using SYSTEM to call sysfs) yet, and the serial comms whilst usable is best regarded as experimental. I've just started work this weekend on adding graphics support using SDL2, but don't hold your breath as I'm exceedingly busy and it's not the only iron I have in the fire. By all means feel free to contribute but note that not only am I probably too busy to coordinate I'm also a brutal code-reviewer .Best wishes, Tom Edited 2024-02-19 10:25 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
I was thinking of something more bare metal. Something we can write on an SD Card, put in the machine, and that's all... the MMBasic environment will be there. It was just a dream |
Dreams need a little help ..... my site |
TBH I'd much rather have a CMM2 than a RPi. It's more useful to me and has more GPIO, including ADC, which is sadly lacking from the RPi. I must confess to having a bit of a soft spot for Python though, it's rather like BASIC on steroids. :) Of course, if you want a RPi-format module that runs MMBasic it's already been done a few times. Edited 2024-02-19 18:40 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6121 |
To be honest, I never really understood the market niche that the Raspberry Pi 1,2,3,4, and 5 are in. That accounts almost same for the Pi-400. You spend around 100 euro's for a (linux) computer, but to be able to use it typically you need a 100+euro screen, and in many cases external storage (100 euro+ USB3-SSD). So you are 300+ euro spending to have "Kabelsalat" on your desk (a mess of wires and cables). Especially if you need sound as wel, and a mouse. Starting from 350 euro's you have a brand new laptop, with everything integrated, having W10 installed, or 200 euro's for a refurbished one. I do see the value of the Raspberry platforms in embedded applications .. absolutely. But not as a desktop replacement. Or ... to play MMBasic games on. Take the laptop, install MMB4W (or the MMB4L if you like linux - or MMB4W in Wine if you like linux). Bare metal would be faster ... that is true. I am sure bare metal on a Pi5 if you use multiple cores (so you need some form of an OS !) could be faster. But in the end you would need support for HDMI, WIFI, network, controllers, USB sticks, Bluetooth, etc. And then bare metal forces you to develop everything yourself (let's call it "peter-self"). Un-doable within even one lifetime. My 5 cents. Volhout Edited 2024-02-19 21:09 by Volhout PicomiteVGA PETSCII ROBOTS |
For a long time I used a Pi3 mounted (VESA mount) behind a display on my electronics workbench with a wireless keyboard and mouse. I would run MMB4L on this and use it as a terminal for working with 'mites. It is very space economical because the keyboard and mouse can just be moved to a shelf above when unneeded. That said more recently for development of the Game*Mite I've mostly been working in my office and using my new / 2nd hand Lenovo T480 laptop running Ubuntu. Best wishes, Tom Edited 2024-02-19 21:25 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
( my $0.05 ) : Pre uefi , I sort of agree . BUT being one who enjoys swapping OS ' s, the RPis are the cats meow ( a quick SD switch and PRESTO new OS ) Obviously I'm part of a minority, but I cannot see how anyone endures Windows and the attendant system oversight. I even have my Wife converted to RPi 4 with FydeOS ..... : ) my site |
Hi Hitsware, All major distributions can be installed in a UEFI environment. Some BIOS's can be set to legacy mode. Volhout PicomiteVGA PETSCII ROBOTS |
I use TwisterOS. it can LOOK like win 98,7,10,11, mac os. You still got to use linux terminal though to do "stuff", yawn :( |
But not with nearly the ease ( cheap P.C.s anyways ) as before .... my site |
Yes .... I've managed to run some Windows programs with Twister .. my site |
