Local Time 14:48 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Does this work as an audio filter?
Posted: 09:08am 18 Feb 2024
There is an interesting video on youtube in which the presenter describes the two-tee notch filter
If I understand it properly and have calculated correctly component values of 820 ohm and 2.2nF should give a "notch" at close to 44100Hz with just two common component values. Could one of our SPICE gurus please model this for me. I've attached the protel net list if it helps
J1
SIP2
Conn_2
J2
SIP2
Conn_2
C1
package name for PCB layout
2.2nF
C2
2.2nF
C3
2.2nF
C4
2.2nF
R5
AX3_1N
820
R1
AX3_1N
820
R2
AX3_1N
820
R3
AX3_1N
820
R4
AX3_1N
820
GND
C1-2
C2-2
J1-2
R5-2
J2-2
N000002
J1-1
C3-1
R1-1
N000003
C3-2
R5-1
C4-1
N000004
R1-2
R2-1
N000005
R2-2
R3-1
C2-1
C1-1
N000006
R3-2
R4-1
N000007
R4-2
C4-2
J2-1
Edited 2024-02-18 19:09 by matherp
stanleyella
Posted: 04:07pm 18 Feb 2024
Would the existing filter be better? harmonics of the carrier, dunno?
Posted: 04:13pm 18 Feb 2024
  Quote  Would the existing filter be better? harmonics of the carrier, dunno?
This one is much cheaper if it works - all JLC "basic" components
stanleyella
Posted: 04:49pm 18 Feb 2024
it's a notch not a bandpass filter. nothing over 12khz would be realistic imho. stan
I bought a pack of 5 inductors £3 free p&p
Edited 2024-02-19 02:51 by stanleyella
Posted: 05:28pm 18 Feb 2024
Volhout's inductor filter is a low-pass at a bit below 44.1kHz. It's very steep (because it's an inductive resonant system) and virtually kills everything from 44.1kHz upwards, while passing everything below about 16kHz.
A notch filter is centered on one particular frequency and will attempt to kill that completely. However, it probably won't take out the harmonics. Centered on 44kHz it would pass 88kHz and 1.32MHz etc. I don't think it would be ideal in this instance unless followed by a low-pass type to take out the harmonics.
Unfortunately I'm no expert on filters (or Spice) - Volhout is your guy. :)
Posted: 05:33pm 18 Feb 2024
My understanding was that Volhout's design is also a notch because he was concerned about 48K PWM rates not being suppressed as well as 44100
Turbo46
Posted: 07:24pm 18 Feb 2024
I went to this site and entered the R and C values and got this result:
I think the result is similar to Volhout's LC filter but it needs a low pass filter before it as in Volhout's circuit to reduce the higher frequencies.
hitsware2
Posted: 07:37pm 18 Feb 2024
Isn't the purpose here to rid audio of clock noise ?
my site
Posted: 07:38pm 18 Feb 2024
&You may be right, Peter. As I said, I'm not an expert at filters. I *think* the output cap to ground forms part of the low pass though.
stanleyella
Posted: 07:56pm 18 Feb 2024
end of the day are you happy with the filter in the manual, which seems to have used preferred value caps. it was never supposed to be "hi fi" but now flac files??
anyone tried an opposing carrier to cancel out the audio carrier and leave the audio?
Turbo46
Posted: 08:04pm 18 Feb 2024
An RC filter is needed to recover an AC audio signal from the PWM signal and to roll off the higher frequencies. However it will still contain remnants of the PWM signal. Some people consider that undesirable.
The purpose of the Twin T filter or the LC filter is to remove, or greatly reduce, the 44.1kHz PWM carrier part of the audio. Earlier designs did not include the notch filter.
