Local Time 20:18 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hmmm, need a bit more testing but...
PhenixRising
Posted: 09:03pm 08 Feb 2024
Geoff, Pete, Gerry...
We might be looking at something never with a Basic interpreter before. Let's see over the next few days.
If it works out, I be makin noises bout dis
PhenixRising
Posted: 09:07pm 08 Feb 2024
Wow was my message hijacked?
Who talks like that.
stanleyella
Posted: 09:30pm 08 Feb 2024
usb seems interesting, where will it go?
PhenixRising
Posted: 09:48pm 08 Feb 2024
I seriously have some things going on with the H71. Could be huge in machine control 😁
IanT
Posted: 08:50am 09 Feb 2024
"Could be huge in machine control"
I'd like an Off-Line GRBL Controller for my Birthday please PR  :-)
IanT
PhenixRising
Posted: 09:36am 09 Feb 2024
  IanT said  "Could be huge in machine control"
IanT
Meh, don't do stepper stuff, only proper motors
Posted: 09:54am 09 Feb 2024
Nothing less than those weedy 30kW jobs, I hope. ;)
IanT
Posted: 11:11am 09 Feb 2024
No Stepper Motor control required PR.
Offline Controllers just feed G-Code (basically text generated by the CAM system) to the GRBL controller (on the CNC router) instead of needing a 'connected' PC running UGCS (Universal G-code Sender) or something similar like Candle. They (G-Code Senders) also allow you to manually 'jog' X/Y/Z machine movements (to zero out 'Z' axis for instance) and usually have lots of other graphical bells and whistles...
I've been thinking about something simpler than UGCS, to give 'jog' functions and perhaps some simple G-Code 'Macro' operations whilst displaying a DRO-like display on screen. Should be possible to build a standalone solution using MMB, maybe with a PicoMite VGA. It's on my wishlist but unlikely to happen unless I find something to give me a big leg-up time-wise (remembering I'm not exactly a programming expert).
However, I'm still looking forward to seeing what you might have in store for us!
IanT
Edited 2024-02-09 21:13 by IanT
IanT
Posted: 11:15am 09 Feb 2024
  Mixtel90 said  Nothing less than those weedy 30kW jobs, I hope. ;)
I only have a very weedy 300W I'm afraid Mick
IanT
PhenixRising
Posted: 11:22am 09 Feb 2024
I was an early adopter of closed-loop AC Vector (FOC) drives, mainly 100HP and 40HP.
Big-enough servos weren't available. Low inertia Reliance motors. Wonderful things to work with
Always dual-loop feedback, encoder on the back of the motor and another on the actual load.
PhenixRising
Posted: 11:27am 09 Feb 2024
  IanT said  No Stepper Motor control required PR.
IanT
Have you ever checked-out GRBLgru? I was chatting with the author. Super-nice guy. Offered to create any model I needed.
PhenixRising
Posted: 02:11pm 15 Feb 2024
Well I wasn't anticipating (or needing) such fantastic performance.
This has to be a world's first
High performance closed-loop Position and Velocity control under interpreted Basic
ArmMite H7
$5 LMD18200 H-Bridge module
DC Motor with HEDS encoder. 500 line = 2000 quadrature counts/rev
LS7366 SPI Quadrature decoder/counter
ArmMite Basic
Full Proportional-Integral-Derivative (PID) filter
Integral limit
Velocity Feed-Forward
Acceleration Feed-Forward
Torque Limiting
Output Offset (to compensate for external influences, such as gravity)
PID Loop rate: Currently 1ms (industry standard) but could easily handle 500us
No "Sync" that we have in PicoMite Basic and so I profiled (surprisingly good):
Velocity regulation is amazing, considering the simple H-Bridge:
Command Velocity: 300,000 quad cts/sec = 150 revs/sec (2000 cts/rev) = 9000RPM
Cmd: The PWM%. This is "Antiphase PWM", meaning that 50% duty-cycle is zero output to the motor.
Err: Command_Position - Actual_Position. Velocity Feed-Forward (VFF) applied.
Vel: Actual motor velocity in quadrature counts/sec.
Steady state maintains zero position error. Force the motor shaft out of position or turn it with motor power (32V DC) off and it will jump right back.
Now to implement Trapezoidal and S-curve velocity profiling, master/slave gearing and interpolation with other units
This thing has all kinds of possibilities.
Posted: 07:07am 16 Feb 2024
What frequency do you run the PWM?
Does it run in sync with the main pid loop, or free running? Using the inertia in the motor as a low pass filter.
You can use SETTICK to creat an interrupt driven accurate loop.
Edited 2024-02-16 17:10 by Volhout
Posted: 08:21am 16 Feb 2024
Hi PhenixRising,
You mentioned the word FOC. Maybe we can chat a bit about something on my horizon.
Do you have experience with FOC on a hysteresis motor.
What I am looking for is some experience how wide the FOC window is..
The Hysteresis motor typically is driven by the frequency needed to achieve the required rpm (like the 1960's record players drive by 50Hz). Due to the inertia they spin up slowly forced by the edi current losses. But once the reach the rpm matching the frequncy, they behave like BLDC motors (or permanent magnet AC motors). And these can be controlled with FOC very good.
I am interested how wide the rpm window is that they can be controlled using FOC. IS that 1% of rpm, or 0.1%, and can it be influenced by bandpass filters on the current channels.?
Looking out for your response.
PhenixRising
Posted: 10:03am 16 Feb 2024
  Volhout said  What frequency do you run the PWM?
Hi Volhout,
The PWM is running at 18KHz and runs in the loop. However, it is only temporary for desktop testing/development. The DACs will take-over, eventually, as I drive a motor-command of +/- 10V. The H7 has 12bit DACS which is just perfect
I have to say that I am quite impressed with this crude setup, totally stable. I have to grab the motor shaft to know if the loop is running
I started-out with SETTICK but it's limited to a resolution of 1ms. This 1KHz is more than adequate for the application (the consensus is 10 X the bandwidth of the machine) but my code execution time is currently < 200us. I have a bit more to add but I don't see it going past 300us. So now I have the option of running the loop at 2KHz.
PhenixRising
Posted: 10:12am 16 Feb 2024
  Volhout said  Hi PhenixRising,
Actually not a fan of FOC. Only used them out of necessity. I much prefer the simplicity of hall-effect commutation. The DSPs and Park-Clarke transforms are a heck of an achievement but there is a tuning process required and for this, the motor must be decoupled from the load. This is one thing in the lab but in the event of a drive-replacement in the field and the 40HP motor is 5m above the floor....
