Local Time 20:45 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite...declaring colors?
apalert
Posted: 09:36am 29 Jan 2024
Hello folks, bit stumped on this...
Using SSD1306 oled with Picomite, have been able to use something like
   LINE x1, y1, x2, y2,  , bg
to get a line drawn on the oled  in the background color.
However I like using OPTION EXPLICIT/OPTION DEFAULT NONE  but that makes the above code crash out saying bg is not declared. Any help appreciated!
Posted: 09:47am 29 Jan 2024
Hi apalert
"bg" is not a keyword, but a variable
You must
DIM bg=RGB(BLACK)
Or the color you want to use
apalert
Posted: 10:46am 29 Jan 2024
  Volhout said  Hi apalert
You must
DIM bg=RGB(BLACK)
Thanks Volhout, much appreciated
