Local Time 20:58 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : local time to UTC and Sidereal Time
RicM
Posted: 08:55am 29 Jan 2024
Dear Members,
Has anyone done a program to convert Local Time to UTC , Atomic Time , Sidereal Time. Look I know there are APP’s for this but the fun of programming it.
RicM
barewires
Posted: 09:16am 29 Jan 2024
Check out Sky & Telescope
https://skyandtelescope.org/astronomy-resources/basic-programs-from-sky-telescope/
SimpleSafeName
Posted: 01:25pm 29 Jan 2024
This led to a fun little excursion. Me being too lazy to download the files one by one, so I opted for my old friend "wget.exe".
It probably would have been quicker to download them individually, but I got to play with a bit of regex and sleuthing around the web page source to get the proper links to the files.
But in case anyone is interested, I've included the files in "Sky & Telescope.zip"
Sky & Telescope BASIC Files.zip
Disclaimer: These are a copy of the files kindly provided by Sky & Telescope, and are provided as-is.
barewires
Posted: 02:42pm 29 Jan 2024
I would highly recommend DownThemAll extension on Firefox / Mozila to get all the files with one click.
https://www.downthemall.org/
https://celestrak.org/software/satellite/sat-trak.php
Has a huge collection of software relating to earth satellites.
I am going to revive a line-number remover with label creation that will accept a serial .bas file input and create a serial output file.
Edited 2024-01-30 02:21 by barewires
SimpleSafeName
Posted: 05:20pm 29 Jan 2024
Good to know! I don't use Firefox, but I'm sure that it is available for other browsers. I thought about looking for an easier option, but wget and I have a long history. :)
GerryL
Posted: 02:51am 30 Jan 2024
RicM,
Attached are my MMBASIC astronomical routines (from Jean Meeus' Astronomical Algorithms) that will have some of the routines you were after.  There is a pdf in the zip folder that explains the routines.
The astronomical routines are in an include file (MMB_Astro.inc) with a BASIC test file (AstroTest.bas ). The test file compares my routine outputs to the US Naval observatory MICA2 program. This creates a text file of the errors, but note if running this on Windows you may need to change line 160 of AstroTest.bas to the folder you want the output text file to be saved in.  It’s been some time since I played with these but the test program should work out of the box on the Windows version of MMBASIC, but note the include file is quite large.
Hope you can extract what you need from this.
Gerry
MyZip.zip
