Forum Index : Microcontroller and PC projects : Picomite Csub creation on windows computer
| morgs67 Regular Member Joined: 10/07/2019 Location: AustraliaPosts: 78 |
Hi, Starting again to produce a picomite Csub. Could anyone help by listing the directory/folder setup they use? Along with the current files required in each folder. TIA Tony |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1772 |
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16350 Best regards Michael Here is my setup for CMM2 Please make sure to use the current header file from the distribution package. Edited 2024-01-27 20:47 by twofingers ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Thanks Michael, I will follow your setup and see how I go. I have found a lot of the references. So will see what happens this time. BR Tony |
