Local Time 12:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picoflap
     Page 1 of 4
Posted: 08:19pm 12 Jan 2024
Posted: 08:21pm 12 Jan 2024
Just a teaser....
It is 10 years ago that flappy bird was taken out of the APP stores because "it was addictive" ....
It is far from finished... so patience....
Edited 2024-01-13 06:24 by Volhout
Amnesie
Posted: 09:27pm 12 Jan 2024
Haha!! How cool is that?! Nice!
Posted: 08:12pm 14 Jan 2024
Here is the first version of the flappy bird game for picomite VGA.
It took met almost 6 hours to complete. Most of it in graphics design.
SPRED102 is your best friend, as is MS PAINT.
Game mechanics
- you control the bird with the space bar, that makes the bird fly higher
- avoid hitting the pipes
- just try to get as far as you can
known issues:
- the game ending does not show the score board and the medals, it just stops
- there are no sound effects yet, only the music.
- collision detection is not perfect.
to do list
- game ending and medals
- LCD version
- controllers.
Have fun playing....
flappy7.zip
Unzip all...
RUN "FLAPPY7.BAS"
P.S. if you find it difficult to play, change line 76 "v=-8" to "v=-7"
Edited 2024-01-15 19:14 by Volhout
Martin H.
Posted: 12:07pm 15 Jan 2024
looks like the Zip File is corrupt.
nul.spr couldn't be extracted
Edited 2024-01-15 22:07 by Martin H.
'no comment
Posted: 12:20pm 15 Jan 2024
Re-zipped....
RUN "FLAPPY8.BAS" with minor changes.
flappy7.zip
It is a stupid simple game, not in the league of any other. Too simple.
Edited 2024-01-15 22:23 by Volhout
Posted: 01:11pm 15 Jan 2024
Simple is good.
Looking forward to the GameMite version.
Posted: 06:31am 16 Jan 2024
Hi Geoff,
The LCD version will be quite different. Re-think from bottom up. The VGA version uses SPRITE commmands that may not be available as BLIT. Such as SPRITE SCROLL and SPRITE MOVE. And it has a loop tick of 50ms, with pixel scroll, where PETSCII had 100ms ans scrolled in 24 pixel blocks.
I will take up the challenge, but first want to finish this VGA version.
Edited 2024-01-16 17:02 by Volhout
Martin H.
Posted: 09:52am 16 Jan 2024
Harm,
Can you publishe the mp3 for the SFX. I can convert them to 8Bit Mono 16kHz Waves and add them to the MOD (as ususal).
  Martin
'no comment
Posted: 10:11am 16 Jan 2024
  Volhout said  The LCD version will be quite different. Re-think from bottom up. The VGA version uses SPRITE commmands that may not be available as BLIT. Such as SPRITE SCROLL and SPRITE MOVE. And it has a loop tick of 50ms, with pixel scroll, where PETSCII had 100ms ans scrolled in 24 pixel blocks.
IIRC the Game*Mite's ILI9341 can hardware scroll to the left/right when in landscape orientation (or up/down when in portrait orientation), I'm sure @matherp has posted some *magic* for setting the appropriate "registers" ... it was perhaps even mentioned by him in the PETSCII Robots thread.
Posted: 08:16am 17 Jan 2024
Hi Martin,
I did send this yesterday, but the post did progress to the thread.
So here ... re-try....
This is the SFX that I found and think sounds good.
The music MOD file is in the flappy7 folder.
If you would be so kind to combine them. Much appreciated !!
flappy_sfx.zip
@Tom,
I will look at this, but the current flappy implementation scrolls the N layer 1 pixel per 90 loops, and the L layer 1 pixel per loop. To be honest, the N layer (background scroll) is not essential, just eye candy for those who master 10 pipes...
But there is a lot to change before the LCD version does approximately the same as the VGA version. I may have to revert to 2 pixel scroll per 100ms, and change all the sprites to a binary library like PETSCII.
Edited 2024-01-17 18:17 by Volhout
Martin H.
Posted: 09:51am 17 Jan 2024
here the Mod with SFX
modsample 16 = Die
modsample 17 = Hit
modsample 18 = Swosh
modsample 19 = Wing
ssl3sfx.zip
'no comment
Posted: 09:55am 17 Jan 2024
Hi Martin,
That is fast..!!! I am excited !!! Will try this tonight.
Martin H.
Posted: 10:07am 17 Jan 2024
  Volhout said  Hi Martin,
since you only have 4 SFX samples, you can also use a separate channel (1-4) for each one.
This has the advantage that they don't get in each other's way when playing.
Good Luck
Martin
Edited 2024-01-17 20:08 by Martin H.
'no comment
Posted: 10:21am 17 Jan 2024
Quick test...
Is there any way to make the music less loud ? Or the sfx louder ? The SFX are almost inaudible because the music is so loud. I guess you need 6 or even 12 db difference.
Edited 2024-01-17 20:31 by Volhout
Martin H.
Posted: 10:39am 17 Jan 2024
  Volhout said  Quick test...
Is there any way to make the music less loud ? The SFX are almost inaudible becuase the music is so loud.
hmm
I don't know a quick method, but I can make every single instrument of the music a little quieter and the SFX as loud as possible.
sll3sfx2.zip
I hope this does the Job
Edited 2024-01-17 20:42 by Martin H.
'no comment
Posted: 11:07am 17 Jan 2024
Hi Martin,
This is good. Thank you !!
Posted: 12:50pm 17 Jan 2024
All,
It was less work than I thought, so I finished functionality of flappy bird for picomite VGA (tested on V50800RC3).
I consider this as the first release candidate. Any feedback will be appreciated.
Implemented is only keyboard control (only the <space> bar).
flappy10.zip
Unzip all to your SD card or A: drive.
Then RUN "FLAPPY10.BAS".
Have fun with this game,
Martin H.
Posted: 01:09pm 17 Jan 2024
Be careful, the game can be addictive,
but it's a nice, simple game . And I'm so bad at it
when unpacking I had problems with the nul.spr.. (nul is a devicename in Windows)
I replaced them with one.spr in the listing..
Edited 2024-01-17 23:21 by Martin H.
'no comment
Posted: 02:20pm 17 Jan 2024
Hi Martin,
Never heard of this. There always is a surprize...
Then this should work...
Renamed the file inside the ZIP to "nulll.spr" and changed the program to work with the new name.
flappy10_1.zip
     Page 1 of 4
