Local Time 21:13 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [PicoMiteVGA] - Game of Life
PEnthymeme
Posted: 07:34pm 09 Jan 2024
Long time lurker as they say.
First up - thank you for a great community and re-igniting my latent passion.  Potted history - grew up on ZX81/Spectrum, moving to "PCs".  Industrial computing background (first paid program was a simulation of engine mounts in GW-BASIC), moved on as we do.
Found the "'Shed" during lockdown and went "PicoMite".
PicoMiteVGA is just about the "perfect" tinkering tool - powerful yet "BASIC" ;-)
Recently been tinkering with getting an "art" project up and running, based on Conway's Life.
PicoMiteVGA to RCA adapter (Amazon) and one of those reversing screen sold for cars (eBay).
Here seen running... (don't judge the set up)
The code... using sprites to save using arrays for the current and next generation. Added some "mutations" to keep things alive - resets after 100 generations...
'Based on Conway's Game of Life - PicoMiteVGA
'Grid Size
MODE 1
Const WIDTH = 340
Const HEIGHT =200
Const CELL = 10
Gens = 0
CLS
FRAMEBUFFER CREATE
createSprites()
'Create some sprites to copy for the cells
'set up inital screen
FRAMEBUFFER WRITE F
For x = 10 To WIDTH Step CELL
 For y = 10 To HEIGHT Step CELL
   alive = Int(Rnd*2)
   If alive = 1 Then
     Sprite WRITE 1,x, y
   EndIf
 Next
Next
FRAMEBUFFER COPY f,n
'main loop
gens = gens + 1
If gens = 101 Then Run
'clear out the next screen
FRAMEBUFFER write f
CLS
Colour RGB(white)
Text 0,260, "Generation " +Str$(gens)
Colour RGB(black)
   FRAMEBUFFER write n  'count neighbours on current
   aliveNeighbours = countNeighbours(x,y)
   pixCol = Pixel(x+5,y+5) 'move to cell centre
   FRAMEBUFFER write f  'move back to new screen for all updates
   If pixCol = 16777215 Then
     If aliveNeighbours <2 Or aliveNeighbours > 3 Then
       Sprite write 2,x,y
     Else
       Sprite write 1,x,y
     EndIf
   Else
     If aliveNeighbours = 3 Then
       Sprite write 1,x,y
     EndIf
   EndIf
   'spontaneous creation and dying - added to allow sim to run longer
   mutate =Rnd()
   If mutate < 0.01 Then
     Sprite write 2,x,y  'spontaneous death
   ElseIf mutate > 0.999 Then
     Sprite write 1,x,y  'spontaneous life
   EndIf
 Next y
Next x
FRAMEBUFFER copy f,n
Loop
Function countNeighbours(x,y)
 count = 0
 For dx = -10 To 10 Step CELL
   For dy = -10 To 10 Step CELL
     If (dx= 0 And dy=0) Then
     ' dont count yourself
     Else
         nx = (x+dx+WIDTH) Mod WIDTH
         ny = (y+dy+HEIGHT) Mod HEIGHT
         pixCol = Pixel(nx+5,ny+5)
           count = count + 1
         EndIf
     EndIf
   Next dy
 Next dx
 countNeighbours = count
End Function
Sub createSprites()
 Colour RGB(black)
 Circle 10,10,5,,,,RGB(white)
 Sprite read 1, 5,5,15,15
 Colour RGB(black)
 Circle 10,10,5,,,,RGB(black)
 Sprite read 2, 5,5,15,15
End Sub
I know "life" is computationally intensive with the looping over all the "cells" and their neighbors -- but open to suggestions how to make things faster as at this resolution to update is acceptable for an art project, but generally "slow" compared to the games I see here.
The next step will be to change the mutations to either read and LDR or temperature and mutate based on environmental conditions.
Anyways - that's me - finally dipped my head above the parapet.
Px
Posted: 08:15pm 09 Jan 2024
Thank you for your first contribution.
The code is very clear and well written.
About speed
The sub that counts neighbors is eating 90% of the cpu cycles.
Any tuning should be in that sub for best performance.
One thing could be to avoid calculations for every cell counted.
There are 8, and they are at fixed relative positions from x,y.
X-5,y-5
X+15,y-5
Etc…
Nice VGA to CVBS converter. Some people on this forum are looking for such converter.
What is the type?
Posted: 08:39pm 09 Jan 2024
Mini VGA to BNC
Nice work--thanks for posting. And welcome to the interactive part of the forum.
PEnthymeme
Posted: 09:36pm 09 Jan 2024
X-5,y-5
X+15,y-5
Etc…
What is the type?
Nice - will see what I can do there - one for tomorrow.
The CVBS is as @lizby posted - had it for a while via slow boat from who knows where - another lockdown "treat".
Long term, i'll make up a PicoMite VGA on protoboard for this as I wont then need the SD card / Keyboard and it'll be quite compact then - ideally fit directly behind the monitor itself - the plan will then be to mount it on a self as "art"  -- Or so I keep telling my other half as I try to convince her I'm not a hoarder.
Posted: 09:45pm 09 Jan 2024
The sd card may be essential. There are cheap, breadboard friendly modules.
PEnthymeme
Posted: 11:04pm 09 Jan 2024
  Volhout said  The sd card may be essential. There are cheap, breadboard friendly modules.
Are the micro SD card modules functionally the same or do I need a full sized SD Card?
P
Posted: 11:13pm 09 Jan 2024
They are the same. If you have a spare micro/standard SD adapter here is an option.
SD Card pins (bottom view)
nc CS MOSI ⏚  3V3 SCK  ⏚ MISO nc
  _______________________________
 / 1   2   3   4   5   6   7   8 |
/9 CS MOSI ⏚  3V3 SCK  ⏚ MISO nc|
|nc                              |
Edited 2024-01-10 09:17 by phil99
PEnthymeme
Posted: 11:24pm 09 Jan 2024
 / 1   2   3   4   5   6   7   8 |
|nc                              |
Reminds me of PS3 modchipping (so I am told)
What's the cap F - 0.1uF?
P
Posted: 11:41pm 09 Jan 2024
The cap filters the 3V3 supply and is optional, most µSD cards don't need it.
If the card doesn't always respond add 10µF, a 100µF was in front of me so I put it on, though not needed for that card.
Posted: 12:33am 10 Jan 2024
  PEnthymeme said  Are the micro SD card modules functionally the same or do I need a full sized SD Card?
This micro SD module works well for me, with maybe a half-dozen hooked up to picomites.
Some have said that the inline resistors on that module might cause problems, but I haven't seen any. Wired one with flying leads a few days ago to the bottom row of pins on one of these:
stanleyella
Posted: 12:34am 10 Jan 2024
works but small display (on small vga) and slow refresh sorry. zx spectrum was fast.
Posted: 07:18am 10 Jan 2024
Maybe this could help improve
See chapter 17
Graphics Programming
Posted: 08:22am 10 Jan 2024
@lizby
I traced the circuit of one of those uSD card modules. There are two supply decoupling capacitors and pullup (not inline) resistors on the signal pins. As the resistors are pretty high in value (10K) they don't seem to have any effect. I've used these a few times now with no additional decoupling and they've always worked well for me. Note, they are a true 3V3 module. There is no level shifting so they are ideal for a Pico.
Another fan of the RP2040-Zero. :)
Edited 2024-01-10 18:25 by Mixtel90
NPHighview
Posted: 04:00pm 10 Jan 2024
PENthymeme - welcome!
VegiPete provided an excellent set of routines for neighbor detection and generation, uh, generation :-) I adapted those routines for a version of LIFE described in this posting.
My setup is mainly based around the WaveShare boards, many of which have integral SD card receptacles. I have yet to try the PicoVGA, which (from what I hear) works much faster on screen updates than LCDs. Curious to see what kinds of speeds you see.
twofingers
Posted: 04:44pm 10 Jan 2024
@PEnthymeme: Welcome!
  PEnthymeme said  ... but open to suggestions how to make things faster as at this resolution to update is acceptable for an art project, but generally "slow" compared to the games I see here.
How about using CSubs to count neighbors?
My version  took ~6ms/gen for a 64x64 field on a CMM2.
  PEnthymeme said  The next step will be to change the mutations to either read and LDR or temperature and mutate based on environmental conditions.
Interesting idea!
Regards Michael
Edited 2024-01-11 02:51 by twofingers
The lone and ...
