Local Time 21:12 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sprites Order
LeoNicolas
Posted: 07:41pm 05 Jan 2024
Hello everyone
I think this is a question for matherp
The sprite show safe command has a parameter we can use to move the sprite to on top of the other ones. Is it possible to modify the same command to accept something like -1 and move the sprite to the bottom of the stack?
This will be very useful for shadow sprites
Posted: 10:55pm 05 Jan 2024
  Quote   Is it possible to modify the same command to accept something like -1 and move the sprite to the bottom of the stack?
No.This would require hiding all sprites first to re-order the stack. That isn't the way it works
