Forum Index : Microcontroller and PC projects : HLK-LD2420 Radar Sensor
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2052 |
I am trying to use one of these modules as a detector for an alarm, but the output always seems to be high even if I cover the module with a metal box. The datasheet says the output is "Inductive output high level" but I don't know what that means. Has anyone had any experience with this module. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382 |
Data sheet / user manual here GitHub link here Its described as a micro-motion sensor with 8m range so it probably needs to be fixed to a rigid surface with no moving objects within range. Putting it in a metal box may be swamping the receiver as it is probably intended for a very weak return signal. The manual mentions its firmware needs to be setup by connecting it to a PC (via TTL/USB adapter) and using configuration software "HLK-LD2420_TOOL". |
Thanks, I have read all that, I just wanted to know whether it outputs a 1 or 0 on the output pin. I covered it with the metal box to try and stop it receiving any motion just to test but it still outputs a 1. Edited 2023-12-30 10:43 by palcal "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| aFox Senior Member Joined: 28/02/2023 Location: GermanyPosts: 110 |
Its like a translation of a Japanese user manual of a record player in the 70s. "Turn the arm 360° around." I have some experiences using radar sensors in 80s and 90s. These sensors detect not a motion. These measure the time gap between sending and receiving. Maybe anything is in the background reflecting the signal. Set the sensitivity to the lowest level. The sensor should now not detect anything. If you still get a signal, there is a fault in the circuit or the sensor itself. If you do not get a signal, increase the sensitivity gradually. When you get a signal, turn the sensitivity back a step or two. Now your sensor should be ready. Happy new Year to all! Gregor Edited 2024-01-01 03:16 by aFox |
My sentence "These sensors detect not a motion." needs a correction. Some sensors compares two or more time gaps. If these are different a motion detection signal will be true. Gregor |
| stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807 |
'VL53LOX instead? OPTION EXPLICIT OPTION DEFAULT NONE Dim d$ Const i2caddr=&H29 I2C write i2caddr,0,2,&H89,&H1 Font 2 Pause 200 CLS Do getdistance Pause 100 Loop ' Sub getdistance I2C write i2caddr,0,2,0,1 I2C write i2caddr,1,1,&H1E I2C read i2caddr,0,2,d$ text 0,0,Str$(Str2bin(uint16,d$,BIG),3,0)+" mm " End Sub |
