Local Time 21:25 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite disc operations - help needed
homa
Posted: 10:27am 24 Dec 2023
Hello,
who can help me with the file operations with the Pico?
In the draft user manual for Beta (5.08.00b5) it says on page 90:
The special entry "." represents the parent of the current directory and "."
represents the current directory. "/" is the root directory.
How are parent and current distinguished?
I also cannot copy all files from a directory on the SDcard to the internal memory A: with one command!
copy b2a "*" to "."
Error : The path name format is invalid
Please help me.
Examples are welcome. Thank you very much!
Posted: 11:14am 24 Dec 2023
Looks like a typo - parent should be ".." as per standard
Don't use B2A etc. these version don't support wildcards
e.g. assuming current disk is "A:"
COPY "B:/*.bas" to "."
Edited 2023-12-24 21:38 by matherp
Posted: 12:06pm 24 Dec 2023
Yes, I only discovered this typo a few hours ago (serendipity?)
The parent should be ".."
Posted: 12:28pm 24 Dec 2023
The A2A etc versions are redundant as you can now use the disk designator in the copy command. They also don't have the bulk copy capability so I would propose you remove them from the manual and I'll get rid in the firmware
homa
Posted: 02:26pm 24 Dec 2023
Thx
Edited 2023-12-25 00:27 by homa
Posted: 03:41am 25 Dec 2023
  matherp said  The A2A etc versions are redundant as you can now use the disk designator in the copy command. They also don't have the bulk copy capability so I would propose you remove them from the manual and I'll get rid in the firmware
Will do.
