Local Time 21:25 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4W: Function error, possible bug?
LeoNicolas
Posted: 06:11am 24 Dec 2023
The following code ends with the error: Error in line 15: FUNC is not declared.
option explicit
main()
sub main()
   local i%
   for i%=0 to 4
       func1()
   next
end sub
function func1() as integer
   func1=10
end function
If I change the code as follows it works fine:
option explicit
main()
sub main()
   local i%, ret
   for i%=0 to 4
       ret=func1()
   next
end sub
   func1=10
end function
Posted: 07:13am 24 Dec 2023
It's a function so it needs to do something with the return.
Because you had no var to accept the return, it went looking for a SUB
Posted: 08:14am 24 Dec 2023
It is tempting to think that something not working as you expected as a bug in the compiler/interpreter - but 99.999% of the time it is not.
We all fall into this trap from time to time.
Posted: 08:26am 24 Dec 2023
Oh yes....
Tell me about it....   :(
I'm forever being outsmarted by a bit of silicon!
LeoNicolas
Posted: 03:22pm 24 Dec 2023
Sorry for my false positive bug post.
This is interesting. I can imagine why It happens. Probably the variable pointer is used directly for the func routine to store the return value, instead of having another memory allocation just for holding the value while the function is executed. Of course I can be completely wrong.
Posted: 03:33pm 24 Dec 2023
  Quote  Of course I can be completely wrong.
Yes. The first thing in a line is always an in-built command or a user SUBROUTINE. A function must always be assigned to something, typically using the in-built command LET which is the default if there is an =
i.e. ret=func1() is actually interpreted ad LET ret=func1()
Func1() at the start of a line fails the interpreter lookup for either an in-built command or a use subroutine hence the error
