Local Time 21:59 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Looking for code for MCP3208 8 channel ADC with SPI interface
karlelch
Posted: 07:29pm 10 Dec 2023
Dear all,
Does someone have code to access the MCP3208 chip via SPI from MMBasic?
Thanks!
oh3gdo
Posted: 08:33am 11 Dec 2023
karleich
I found CCS c-language code for MCP3208
// olympic++  adc de-noising routine for 10 or 12 bit ADC values
// NOTE: you must have selected the desired ADC channel before calling
// reads 16x , sorts and tosses low4 && high 4 readings
// then averages the middle 8
unsigned int16 adchlx(void){  // read 16 - sort, keep middle 8 average
unsigned int8 i;  unsigned int16 accum=0;
unsigned int16 s, b[16]; int1 didswap=1;
  for ( i = 0 ; i < 16;  i++ ) {
          b[i]= read_adc(ADC_start_and_read); // ADC set for 10 or 12 bits
          delay_us(8);
    } //    end of for loop for multi sample
  while(didswap){  // bubble sort
    didswap=0;
    for (i=0; i<15; i++){ // i 0-15
     if(b[(i)]>b[(i+1)]){ // if low element greater than next  -do  swap
          s=b[i]; // hold upper
          b[i]=b[(1+i)];
          b[(1+i)]=s;
          didswap=1;
     } // ~if
    } // ~for
   } // ~while
  // now sort and keep middle 8 values
  for (i=4; i<12; i++){  accum +=b[i];  }
  return(accum>>3);
I think it is not too difficult to change it to MMBASIC
The place is https://www.ccsinfo.com/forum/viewtopic.php?t=50320&highlight=mcp3208
Pekka Ritamaki
zeitfest
Posted: 09:03am 11 Dec 2023
maybe tweak the Basic examples here
( https://microcontrollershop.com/download/adc_examples.zip?osCsid=abnttkhk7ndtssls53d5vimaf4 )
Edited 2023-12-11 19:04 by zeitfest
karlelch
Posted: 10:58pm 11 Dec 2023
Thanks @oh3gdo - I did find C code, too, but for some reason failed to adapt it to MMBasic, specifically the SPI communication.
Thanks @zeitfest - I’ll have a closer look.
