Local Time 15:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : # big font
homa
Posted: 07:29pm 10 Dec 2023
Hi there,
does anyone know how to read the bits (pixels) from the fonts in picomite? For example to print big characters with "#" (like on printers in the past ...) or to display a letter on the 8x8led ;-)
Posted: 07:37pm 10 Dec 2023
If your display is suitable,
Print the text to the display then use the PIXEL function to read each pixel.
disco4now
Posted: 10:12pm 10 Dec 2023
MM.INFO(FONT ADDRESS n) Returns the actual address of the memory location containing the start of the binary data defining FONT n
Then PEEK(BYTE addr%) to access the data.
The data looks like this. First four byte define the fontwidth,fontheight,first charcter in data, number of characters in font , the data then follows.
const unsigned char F_6x8_LE[580] = {
0x06,0x08,0x20,0x60,
0x00,0x00,0x00,0x00,0x00,0x00, // Chr$(32)
0x20,0x82,0x08,0x00,0x82,0x00, // Chr$(33)  !
0x51,0x45,0x00,0x00,0x00,0x00, // Chr$(34)  "
0x51,0x4F,0x94,0xF9,0x45,0x00, // Chr$(35)  #
0x21,0xEA,0x1C,0x2B,0xC2,0x00, // Chr$(36)  $
0x00,0x69,0x90,0x20,0x4C,0xB0, // Chr$(37)  %
0x62,0x4A,0x10,0xAA,0x46,0x80, // Chr$(38)  &
0x60,0x84,0x00,0x00,0x00,0x00, // Chr$(39)  '
0x10,0x84,0x10,0x40,0x81,0x00, // Chr$(40)  (
0x40,0x81,0x04,0x10,0x84,0x00, // Chr$(41)  )
0x00,0x8A,0x9C,0xA8,0x80,0x00, // Chr$(42)  *
0x00,0x82,0x3E,0x20,0x80,0x00, // Chr$(43)  +
0x00,0x00,0x00,0x30,0x42,0x00, // Chr$(44)  ,
0x00,0x00,0x3E,0x00,0x00,0x00, // Chr$(45)  -
0x00,0x00,0x00,0x01,0x86,0x00, // Chr$(46)  .
0x00,0x21,0x08,0x42,0x00,0x00, // Chr$(47)  /
0x72,0x29,0xAA,0xCA,0x27,0x00, // Chr$(48)  0
0x21,0x82,0x08,0x20,0x87,0x00, // Chr$(49)  1
0x72,0x20,0x84,0x21,0x0F,0x80, // Chr$(50)  2
0xF8,0x42,0x04,0x0A,0x27,0x00, // Chr$(51)  3
0x10,0xC5,0x24,0xF8,0x41,0x00, // Chr$(52)  4
0xFA,0x0F,0x02,0x0A,0x27,0x00, // Chr$(53)  5
0x31,0x08,0x3C,0x8A,0x27,0x00, // Chr$(54)  6
0xF8,0x21,0x08,0x41,0x04,0x00, // Chr$(55)  7
0x72,0x28,0x9C,0x8A,0x27,0x00, // Chr$(56)  8
0x72,0x28,0x9E,0x08,0x27,0x00, // Chr$(57)  9
0x01,0x86,0x00,0x61,0x80,0x00, // Chr$(58)  :
0x01,0x86,0x00,0x60,0x84,0x00, // Chr$(59)  ;
0x10,0x84,0x20,0x40,0x81,0x00, // Chr$(60)  <
0x00,0x0F,0x80,0xF8,0x00,0x00, // Chr$(61)  =
0x40,0x81,0x02,0x10,0x84,0x00, // Chr$(62)  >
0x72,0x20,0x84,0x20,0x02,0x00, // Chr$(63)  ?
0x72,0x20,0x9A,0xBA,0x27,0x00, // Chr$(64)  @
0x72,0x28,0xA2,0xFA,0x28,0x80, // Chr$(65)  A
0xF2,0x28,0xBC,0x8A,0x2F,0x00, // Chr$(66)  B
0x72,0x28,0x20,0x82,0x27,0x00, // Chr$(67)  C
0xE2,0x48,0xA2,0x8A,0x4E,0x00, // Chr$(68)  D
0xFA,0x08,0x3C,0x82,0x0F,0x80, // Chr$(69)  E
0xFA,0x08,0x3C,0x82,0x08,0x00, // Chr$(70)  F
0x72,0x28,0x2E,0x8A,0x27,0x80, // Chr$(71)  G
0x8A,0x28,0xBE,0x8A,0x28,0x80, // Chr$(72)  H
0x70,0x82,0x08,0x20,0x87,0x00, // Chr$(73)  I
0x38,0x41,0x04,0x12,0x46,0x00, // Chr$(74)  J
0x8A,0x4A,0x30,0xA2,0x48,0x80, // Chr$(75)  K
0x82,0x08,0x20,0x82,0x0F,0x80, // Chr$(76)  L
0x8B,0x6A,0xAA,0x8A,0x28,0x80, // Chr$(77)  M
0x8A,0x2C,0xAA,0x9A,0x28,0x80, // Chr$(78)  N
0x72,0x28,0xA2,0x8A,0x27,0x00, // Chr$(79)  O
0xF2,0x28,0xBC,0x82,0x08,0x00, // Chr$(80)  P
0x72,0x28,0xA2,0xAA,0x46,0x80, // Chr$(81)  Q
0xF2,0x28,0xBC,0xA2,0x48,0x80, // Chr$(82)  R
0x7A,0x08,0x1C,0x08,0x2F,0x00, // Chr$(83)  S
0xF8,0x82,0x08,0x20,0x82,0x00, // Chr$(84)  T
0x8A,0x28,0xA2,0x8A,0x27,0x00, // Chr$(85)  U
0x8A,0x28,0xA2,0x89,0x42,0x00, // Chr$(86)  V
0x8A,0x28,0xAA,0xAA,0xA5,0x00, // Chr$(87)  W
0x8A,0x25,0x08,0x52,0x28,0x80, // Chr$(88)  X
0x8A,0x28,0x94,0x20,0x82,0x00, // Chr$(89)  Y
0xF8,0x21,0x08,0x42,0x0F,0x80, // Chr$(90)  Z
0x71,0x04,0x10,0x41,0x07,0x00, // Chr$(91)  [
0x02,0x04,0x08,0x10,0x20,0x00, // Chr$(92) backslash
0x70,0x41,0x04,0x10,0x47,0x00, // Chr$(93)  ]
0x21,0x48,0x80,0x00,0x00,0x00, // Chr$(94)  ^
0x00,0x00,0x00,0x00,0x0F,0x80, // Chr$(95)  _
0x00,0xC4,0x8C,0x00,0x00,0x00, // Chr$(96)  `
0x00,0x07,0x02,0x7A,0x27,0x80, // Chr$(97)  a
0x82,0x0B,0x32,0x8A,0x2F,0x00, // Chr$(98)  b
0x00,0x07,0x20,0x82,0x27,0x00, // Chr$(99)  c
0x08,0x26,0xA6,0x8A,0x27,0x80, // Chr$(100)  d
0x00,0x07,0x22,0xFA,0x07,0x00, // Chr$(101)  e
0x31,0x24,0x38,0x41,0x04,0x00, // Chr$(102)  f
0x01,0xE8,0xA2,0x78,0x27,0x00, // Chr$(103)  g
0x82,0x0B,0x32,0x8A,0x28,0x80, // Chr$(104)  h
0x20,0x06,0x08,0x20,0x87,0x00, // Chr$(105)  i
0x10,0x03,0x04,0x12,0x46,0x00, // Chr$(106)  j
0x82,0x09,0x28,0xC2,0x89,0x00, // Chr$(107)  k
0x60,0x82,0x08,0x20,0x87,0x00, // Chr$(108)  l
0x00,0x0D,0x2A,0xAA,0x28,0x80, // Chr$(109)  m
0x00,0x0B,0x32,0x8A,0x28,0x80, // Chr$(110)  n
0x00,0x07,0x22,0x8A,0x27,0x00, // Chr$(111)  o
0x00,0x0F,0x22,0xF2,0x08,0x00, // Chr$(112)  p
0x00,0x06,0xA6,0x78,0x20,0x80, // Chr$(113)  q
0x00,0x0B,0x32,0x82,0x08,0x00, // Chr$(114)  r
0x00,0x07,0x20,0x70,0x2F,0x00, // Chr$(115)  s
0x41,0x0E,0x10,0x41,0x23,0x00, // Chr$(116)  t
0x00,0x08,0xA2,0x8A,0x66,0x80, // Chr$(117)  u
0x00,0x08,0xA2,0x89,0x42,0x00, // Chr$(118)  v
0x00,0x08,0xA2,0xAA,0xA5,0x00, // Chr$(119)  w
0x00,0x08,0x94,0x21,0x48,0x80, // Chr$(120)  x
0x00,0x08,0xA2,0x78,0x27,0x00, // Chr$(121)  y
0x00,0x0F,0x84,0x21,0x0F,0x80, // Chr$(122)  z
0x10,0x82,0x10,0x40,0x82,0x04, // Chr$(123)  {
0x20,0x82,0x00,0x20,0x82,0x00, // Chr$(124)  |
0x20,0x41,0x02,0x08,0x41,0x08, // Chr$(125)  }
0x00,0x04,0xAA,0x90,0x00,0x00, // Chr$(126)  ~
0x00,0x02,0x14,0x8B,0xE0,0x00 // Chr$(127)
Gerry
F4 H7FotSF4xGT
stanleyella
Posted: 10:32pm 10 Dec 2023
Interesting. read pixel ok but thought read character set as said.
