Local Time 13:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picomite (non VGA)
zeitfest
Posted: 09:52pm 09 Dec 2023
I am after small boards that just have the pico and sd micro socket.
Is the non-VGA picomite still current ?
I can't see any suppliers or Silicon Chip kit/pcb etc.
Posted: 10:10pm 09 Dec 2023
Easy to wire up: Seeed RP2040 with micro SD reader
Mick posted a picture of a PCB in the post following the above linked, but I don't think he posted the gerbers. Perhaps he could if you wanted.
Posted: 10:50pm 09 Dec 2023
It's still current. :)
I still have the drawing for that tiny board if you want it, but there's no problem in rustling a custom job up.
zeitfest
Posted: 11:46am 10 Dec 2023
Thanks,  I am thinking a specific design pcb may be best, some time down the track.
ATM I am using a pico with the sd adaptor hanging on wires, and/or the SC backpack. Maybe the backpack without the audio and adding a good A/D and circuit via I2c or spi... next year maybe
Posted: 03:30pm 10 Dec 2023
Mick,
I like the ultra small sd card connector board. Not sure if the pinout allows, but if you could move the sd card pins (SPI) to the perpendicular row, the breadboard friendly parallel pin rows would be free.
Then move the resistor and cap to the card reader side.
Then you could sandwich the 2 boards, especially when the board is 0.8 or 1mm thick, and even use 2.54mm pin headers to make the sandwich breadboard friendly.
Edited 2023-12-11 02:35 by Volhout
Posted: 04:18pm 10 Dec 2023
That's more or less how it is. The uSD card is on:
CS - GP13
MISO - GP12
MOSI - GP11
SCLK - GP10
GP9, also along the end, isn't used. Neither are both the 9-pin sides. The resistor & cap come off 3V3, of course, and are tucked between the rear of the uSD and the end pins. The uSD. They are shown between the Zero and the pcb, but can easily be on the bottom with the uSD.
I've just realized that you have to be careful with the RP240-Zero. In spite of it having castellated contacts you can't SMD it unless you cut a big hole in your PCB as the RP2040 (and most of the rest) is on the bottom of the board. If you want a breadboard friendly arrangement you need to use long headers. It mounts quite neatly upside down on normal headers, but you can't get to the LED and buttons then... Some major re-thinking on my controllers might be in order (although I think I'm ok for space on those).
I've just had a play and, in theory, you could fit normal headers, use a thin pcb and fit the uSD between the pcb and the Zero. However, you'd need a small small SMD resistor and cap  to keep the thickness down. Too fiddly for me.
Would you like me to arrange several of these on a strip? If they are only separated by silkscreen and you cut them yourself there's no extra charge. I can leave a mm or so between them for cutting.
Edited 2023-12-11 04:02 by Mixtel90
homa
Posted: 08:08pm 10 Dec 2023
https://www.sparkfun.com/products/17745
Too expensive for my taste, though.
Posted: 08:53pm 10 Dec 2023
Early in PicoMite development Peter glued a SMD micro SD socket over the logo of a standard Pico.
Soldering thin enameled wire to the socket pins needs good eyes and steady hands.
Posted: 10:09pm 10 Dec 2023
So, four to a strip gets you 20 boards per order. :)
I've tweaked it a bit. The resistor can be a SMD part if you wish. If so, it fits on top of the board and tucks in near the RP2040. A standard resistor can be fitted below the board, behind the uSD socket.
The uSD is actually connected to a hardware SPI, but that doesn't matter. I did it just because I could. :)
al18
Posted: 04:20pm 11 Dec 2023
This microSD breakout board should work fine with the Pico $1.96 on eBay https://www.ebay.com/itm/224067263348?hash=item342b731b74:g:3EQAAOSwHP9iS3gR
Posted: 04:34pm 11 Dec 2023
  al18 said  This microSD breakout board should work fine with the Pico $1.96 on eBay https://www.ebay.com/itm/224067263348?hash=item342b731b74:g:3EQAAOSwHP9iS3gR
That has worked for me, but some have found that in some circumstances, the resistors interfere with successful operation.
Posted: 04:40pm 11 Dec 2023
That one is ok, but ignore the specification in the advert. There is no level shifting and if you put 5V on it you'll blow your SD card up. There are simple pullup resistors and two paralleled supply decoupling capacitors. In theory you shouldn't have the pullups, but they don't seem to do any harm.
The board I've shown uses a SMD holder rather than a module. It's fiddly to solder but I've done a few now. :)  I use a pointed tip - one of the 5W USB irons is good for this.
Posted: 07:40pm 11 Dec 2023
Finally got round to doing the gerbers. Sorry about the delay. :)
RP2040-Zero + uSD.zip
Posted: 08:03pm 11 Dec 2023
Ordered--$4US for 20. Note that I had to replace/remove the "+" in the file name--JLCPCB didn't like it.
If anyone in the U.S. or Canada would like 1 or 2, PM me your address. After I test one, I'll mail them out. No charge--for the good of the MMBasic crew. Slow boat from China, so it will be several weeks.
Thanks, Mick, for all your good work.
PS: If you haven't ordered any, Mick, PM me your address and I'll send you a stick.
Edited 2023-12-12 06:19 by lizby
Posted: 11:30pm 02 Jan 2024
Mick--I received the PCBs. Slow boat was slower than usual for JLCPCB. What are the values for C1 and R1?
Posted: 11:47pm 02 Jan 2024
They are the SD card supply filter. The usual values are 10uF+ and 0R to 2R2.
Edit
For through-hole C1 tantalum or low ESR electrolytic, for SMD ceramic chip.
Edited 2024-01-03 09:58 by phil99
Posted: 07:54am 03 Jan 2024
The micro SD cards seem to be far less critical than the bigger ones. I've often used them without any decoupling but I included it to play safe. :) If you want to live life on the edge too, omit C1 and short out R1.
Somewhere between 1R0 and 10R for the resistor and 100nF upwards for the capacitor. As Phil says, there's no reason not to use 2R2 and 10uF unless you can't get them for some reason.
Incidentally, C1 is a 1206 size SMD component and R1 can be either a through-hole or a 1206. There's no room for a through-hole cap really. The SD card socket is on the bottom of the board, R1 & C1 are on the top. They should just tuck behind the components on the bottom of the RP2040-Zero.
zeitfest
Posted: 12:11pm 04 Jan 2024
I gather these stack onto pi zero boards ?
very compact, looks well done..
don't know much about pi zero though, is it a direct substitute for pico ?
Posted: 12:49pm 04 Jan 2024
They fit underneath the RP2040-Zero (not the Raspberry Pi Zero). It's almost the same as the standard Pico, but with a linear regulator, USB-C connector, WS LED, reset button and less GPIO pins. Unfortunately the pins needed to run it as a PicoMite VGA are missing. This board uses the pins across the end of the board for the SD card so they aren't wasted when you want to plug just the two side rows into something.
They are also reasonably priced from AE - and rather fun to use because they are so cute. :)  The ordinary PicoMite firmware runs on them perfectly.
Posted: 07:52pm 04 Jan 2024
Well, I have two different micro SD sockets, and neither one is right. What is the correct part number for this, and from whom?
