Local Time 15:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION AUTORUN ON
PhenixRising
Posted: 07:09pm 04 Dec 2023
Most of the options are set from the command prompt but can AUTORUN be part of the code?
Martin H.
Posted: 07:22pm 04 Dec 2023
> list
Option AUTORUN  off
> run
> option list
PicoMite MMBasic Version 5.07.08RC21
OPTION SYSTEM SPI GP6,GP3,GP4
OPTION CPUSPEED  252000 'KHz
OPTION DISPLAY 28, 80
OPTION LCDPANEL ILI9341, RLANDSCAPE,GP2,GP1,GP0
OPTION TOUCH GP5,GP7
GUI CALIBRATE 0, 368, 294, 882, 666
OPTION SDCARD GP22
OPTION AUDIO GP20,GP21', ON PWM CHANNEL 2
OPTION MODBUFF ENABLE
Saved 20 bytes
> list
Option AUTORUN  1
> run
> option list
OPTION AUTORUN  1
OPTION SDCARD GP22
> list
Option AUTORUN  on
> RUN
> option list
OPTION AUTORUN  ON
OPTION SDCARD GP22
so, yes it can be part of the Program
Edited 2023-12-05 05:25 by Martin H.
'no comment
stanleyella
Posted: 08:33pm 04 Dec 2023
I only used autorun on in a program. I was told only to use it when the code was debugged.. whenever that is but it's great if you can't remember what a board did :)
Posted: 09:56pm 04 Dec 2023
I think that might be what comments are for, Stan. :)
The advice not to use it until your code is working is good. Especially if you change Break too....
