Local Time 15:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: Memory Pack/Unpack and 2D Arrays
vegipete
Posted: 05:34pm 02 Dec 2023
Is there an efficient way to apply MEMORY PACK and UNPACK to 2 dimensional arrays? Or do I have to resort to a mess of MATH SLICE/INSERT commands in a loop to do this?
Suppose I have
dim a%(63,31)
dim b%(7,31)
I would really like to
MEMORY PACK a%(),b%(),64,8,,2
where the blank parameter indicates to pack along the first index.
Thanks.
Posted: 06:07pm 02 Dec 2023
MEMORY PACK and UNPACK both support arrays or addresses as parameters. So you can PACK by address. Of course the packed array doesn't need to have the same number of dimensions
dim a%(63,31)
dim b%(8*32-1)
MEMORY PACK  peek(varaddr a%()),b%(),64*32,8
should work but untested
vegipete
Posted: 06:37pm 02 Dec 2023
OK, pretty close. Still needs a loop, and some 'esoteric' numbers, but it appears to work:
Option default integer
Dim a(15,7)
Dim b(1,7)
Math set 3,a()
Print "Before"
Print "Unpacked source:"
Math m_print a()
Print "Packed result:"
Math m_print b()
For i = 0 To 7
 Memory pack Peek(varaddr a())+i*64,Peek(varaddr b())+i*16,16,8
Next i
Print "After"
Math m_print a()
Math m_print b()
The output looks like what I would expect.
vegipete
Posted: 06:44pm 02 Dec 2023
Ooooo!
Far simpler: replace the entire loop above with
Memory pack Peek(varaddr a()),Peek(varaddr b()),128,8
