Local Time 16:08 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SSD1963 LCD Timings
GerryL
Posted: 12:32am 28 Nov 2023
In playing around with a driver for a SSD1963 type LCD display I used Techtoys 7 inch datasheet as a guide for setting the timings for horizontal HT, HPS & HPW and vertical VP, VPS & VPW. These work fine on my 7 inch LCD but on my 5 inch display I appear to get some writing during the blanking period.
Noting these timings are probably a little dependent on the manufacturer, does anyone know if there is a rule of thumb or guide for setting these for 5 inch and 9 inch displays based around the 7 inch timings or is it a matter of trial and error noting there is some lee way?
Gerry
Posted: 04:42am 28 Nov 2023
I wrote drivers using the SSD1963 many moons ago for the Micromite Plus and I remember that there was no definitive timing available and, even worse, the timing seemed to vary by the LCD glass used.  In the end I used a lot of trial and error.
You can see my efforts (written in C) by downloading the Micromite source code from https://mmbasic.com/source.html
Edited 2023-11-28 18:01 by Geoffg
GerryL
Posted: 12:11am 29 Nov 2023
Thanks Geoff, considering how extensively these types of displays are used its surprising how little manufacturer's timing information is readily available.
Gerry
