Local Time 16:08 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBASIC MAKING COLOURS VARIABLE
OA47
Posted: 06:13am 22 Nov 2023
Is it possible to make foreground and background colours variables?
Like BGColour$="RGB(100,100,100) and use the string in a TEXT string?
0A47
Posted: 06:54am 22 Nov 2023
colours are a number so MYbackground% = RGB(100,100,100)
then use MYbackground where ever you would use RGB(x,x,x)
OA47
Posted: 08:05am 22 Nov 2023
Thanks Jim, I should have added more information to my predicament. I am trying to use an array to hold the sections of the TEXT command and I if I use a String array I can extract the X and Y co-ordinates, the FONT and SCALE using VAL() , the actual TEXT string is Ok but I cant see a simple way around holding the foreground and background information unless I use 6 more elements to the array.
0A47
Posted: 08:08am 22 Nov 2023
The colour is just a number so yo only need two elements. i.e.
rgb(128,128,128) = &H808080 = 8421504
Posted: 08:13am 22 Nov 2023
You could put the colours into an integer array
c%(2)=(RGB(yellow),RGB(40,40,40),rgb(white))
then store c%(n) as CHR$(c%(n)) in your string
Is that what you mean?
OA47
Posted: 08:17am 22 Nov 2023
Peter how would you elegantly recover the RGB(XXX,XXX,XXX) from a saved string of "8421504"?
0A47
Posted: 08:20am 22 Nov 2023
  Quote   Peter how would you elegantly recover the RGB(XXX,XXX,XXX) from a saved string of "8421504"?X
You don't need to - just use 8421054 in the TEXT command
TEXT 0,0,"hello",,,,8421054,0
is perfectly valid
OA47
Posted: 08:23am 22 Nov 2023
Peter thank you very much. That solves my dilemma instantly.
I have not seen the commands using the numerical form of RGB(xxx,xxx,xxx) before.
0A47
Edited 2023-11-22 18:47 by OA47
