Local Time 16:08 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 3D printed case for matherp's PicoMite-VGA board v1.0
karlelch
Posted: 09:24pm 20 Nov 2023
I created a simple 3D-printable case for Peter's PicoMite-VGA board v1.0 using FreeCAD.
It requires:
- 1x case top
- 1x case bottom
- 2x "button sticks" (to press the two buttons on the PCB)
- 4x feet
- 4x M3 machine screws
- 4x embeddable brass nuts (M3x8x5)
The FreeCAD file as well as the .STL files for the 4 printable parts are in here:
picomiteVGA_case_v2.zip
Here are some pictures:
All parts:
Embedded nut:
"button sticks":
Finished case from one ...
... and the other side.
Thomas
Posted: 10:12pm 20 Nov 2023
Very nice - will try and print one tomorrow
okwatts
Posted: 06:08pm 24 Nov 2023
Thanks for doing this. Now I need to find the metric hardware, especially the embedded nuts. At the moment the case is taped together. Now I need cases for other projects like Mixtel90's Picomite Backpack, and Hydra40-80 with ArmiteF4, etc. My problem is I'm not very good at design and Fusion360.
karlelch
Posted: 02:30pm 26 Nov 2023
  okwatts said  Thanks for doing this. Now I need to find the metric hardware, especially the embedded nuts. At the moment the case is taped together.
This is what I used.
Slightly updated case (picomiteVGA_case_v3.zip):
