Local Time 20:19 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Colours
OA47
Posted: 08:15pm 19 Nov 2023
Has there been a list published that shows the 24 bit R,G and B levels for the inbuilt 8 colours of blue, green, cyan, red, magenta, yellow, brown and gray?
0A47
Posted: 08:54pm 19 Nov 2023
MMBasic accepts 0-255 for R, G & B values then automatically scales them to suit the platform. so Red, for example, is always RGB(255,0,0) even on a Picomite where there is only 1 bit or Red. Consequently the basic colours are easy
Red is RGB(255,0,0)
Green is RGB(0,255,0)
Blue is RGB(0,0,255)
Yellow is RGB(255,255,0)
Cyan is RGB(0,255,255)
Magenta is RGG(255,0,255)
Black is RGB(0,0,0)
White is RGB(255,255,255)
These values are true for all platforms. They can be shortened e.g. RGB(red) or RGB(white)
Brown and Gray rely on there being more control.
The CMM2 uses these values:
Brown is RGB(165,42,42)
Grey is RGB(64,64,64)
You may have to play with these values.
Posted: 08:58pm 19 Nov 2023
   #define BLACK               RGB(0,    0,      0)
   #define BLUE                RGB(0,    0,      255)
   #define GREEN               RGB(0,    255,    0)
   #define CYAN                RGB(0,    255,    255)
   #define RED                 RGB(255,  0,      0)
   #define MAGENTA             RGB(255,  0,      255)
   #define YELLOW              RGB(255,  255,    0)
   #define BROWN               RGB(255,  128,    0)
   #define GRAY                RGB(128,  128,    128)
   #define LITEGRAY            RGB(210,  210,    210)
   #define WHITE               RGB(255,  255,    255)
Posted: 09:08pm 19 Nov 2023
I've found that browns and oranges seem to depend on the monitor and the ambient lighting. They aren't "pure" colours and brown doesn't really exist!
OA47
Posted: 09:12pm 19 Nov 2023
Thanks for the info. I was using the gray color (grey colour) and was not happy with the contrast so now I can play around with the values.
0A47
