Forum Index : Microcontroller and PC projects : Tera Term & Telnet. Is Auto Reconnection Possible?
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1131 |
Hi Is it possible to get Tera Term to reconnect to a Telnet session, or keep checking for the connection if the Telnet connection is lost? e.g. when a Webmite resets. I tried searching on line without any real success. Thanks Brian ChopperP |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6606 |
You could probably do it using TeraTerm scripting. Jim VK7JH MMedit |
Thanks Jim I was hoping that there was something I missed in the set ups somewhere. Will investigate further if nothing else comes up Thanks again Brian ChopperP |
Ok 3 posts?? I wasn't even trying to get to the 1000 mark either Edited 2023-11-12 11:49 by Chopperp ChopperP |
