Forum Index : Microcontroller and PC projects : BITBANG WS2812 Bug !
| amigawizard Regular Member Joined: 15/08/2023 Location: AustraliaPosts: 43 |
V5.07.08 b11 ok V5.07.08 b12 stops at 2136.9 sec Using BitBang after 35 minutes hangs basic Box x * 32 + 2 , y * 29 + 2 , 29 , 26 , , rader , rader + 5 '' 205 '''value%(y + 200) = 256 '1 ' rader 'Bitbang ws2812 O , 4 , 8 , value%(j) '''Pause 2 'If Not rx Then Bitbang ws2812 O , 4 , 255 , value%(j) : rex = 555 : Print rx , me : Inc me Inc rx , -1 If Time$ = "01:00:00" Then Bitbang ws2812 O , 4 , 255 , value%(j) Print Time$ If Inkey$ = " " Then Print " Ok here ", : Bitbang ws2812 O , 4 , 8 , value%(j) : Print " and here 2! " : Inc me ' Chris Posted: at 11:39am on the 28 Sep 2023 35 minutes and 43 seconds. This is the consistent time between each watchdog restart and the subsequent freeze. The last version that worked without doing this for me was V5.07.08B11. Posted: at 05:18am on the 03 Oct 2023 Wayne ! ` |
Is that a working example that demonstrates the failure? John |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12179 |
Try this PicoMite.zip |
yes that is working ! what was the reason ? Wayne !! ` |
