Local Time 22:40 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Detect Collision On Non-Transparent Sprite Pixels
LeoNicolas
Posted: 01:08am 06 Nov 2023
Hello everyone
Is there an out-of-box way to make the sprite interrupt command only call the callback function when the non-transparent pixels of two sprites collide?
In my tests, the callback is called if any parts of two sprites collide, even if the pixels are transparent.
Thank you
Posted: 08:28am 06 Nov 2023
Collision is detected on the sprite boundary. Anything else would be far to processor intensive. All you can do is limit the size of the sprites to the smallest rectangle possible that has non-transparent pixels on each edge
