Local Time 22:53 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4W: Write to Output File Oddness
vegipete
Posted: 12:18am 05 Nov 2023
The following writes nothing to the output file:
option console serial
Dim fname$ = "testfile.txt"
open fname$ for output as #2
print #2, 123
print #2, 456
print #2, "ABCD"
close #2
end
If the first line, option console serial, is commented out, it writes the expected text to the output file. Is this behaviour correct?
I haven't tested this on any other platforms.
