Forum Index : Microcontroller and PC projects : £45 7" nice display
| stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807 |
https://www.buydisplay.com/download/ic/LT7683.pdf looks interesting for price and it's spi |
That's the spec for the controller chip. It's not for a display. Mick Zilog Inside! nascom.info for Nascom & Gemini |
https://github.com/GreatCowBASIC/Help/blob/main/seven_inch_gcld/referencedocs/FocalTech-FT5x26.pdf https://github.com/GreatCowBASIC/Help/blob/main/seven_inch_gcld/referencedocs/SSP0700A.pdf £45 aliexpress |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4380 |
TBH without an explanation and an ali link that's a pain to figure out. John |
Don't hold your breath. I don't think any capacitive touch controllers are supported by MMBasic, and neither is that display controller chip. You can use 800x480 on the Armmite F4 (and there is a cheaper IPS display that will do it - I did a PCB for it) but not the PicoMite as you can't have a frame buffer that big. Mick Zilog Inside! nascom.info for Nascom & Gemini |
It was posted on gcbasic forum as under development. A smart lcd that an 8bit controller can use. bit like nextion but cheaper and no ide needed. |
Now, if you'd said that at the beginning.... :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
this for pico vga? https://www.aliexpress.com/item/1005004670710687.html |
