Local Time 23:07 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: Experimental version for comment
Posted: 10:33am 17 Oct 2023
This version is just for the PicoMite. If generally of interest and robust it will become the main PicoMite version
PicoMite.zip
Installing this will delete everything on the Pico
What's different?
I've freed up 16K of memory by using the VGA version of function handling. This does slow very complex programs with many functions and subroutines by up to around 7% but performance is still the same as the VGA version
This is targeted at complex graphics (e.g. games)
Preconditions for new command
FRAMEBUFFER and LAYERBUFFER are created i.e.
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
New command
FRAMEBUFFER MERGE [colour] [,mode]
Usage
FRAMEBUFFER MERGE - writes the contents of the framebuffer to the physical display overwriting any pixels in the framebuffer that are set in the layerbuffer (not zero)
FRAMEBUFER MERGE col - writes the contents of the framebuffer to the physical display overwriting any pixels in the framebuffer that are in the layerbuffer not set to the transparent colour  "col"
FRAMEBUFFER MERGE col,B - as above except that the transfer to the physical display takes place on the second processor and control returns to Basic immediately
FRAMEBUFFER MERGE col,R - sets the second processor to continuously update the physical display with the merger of the two buffers. Automatically sets FRAMEBUFFER WRITE F. NB: FRAMEBUFFER WRITE cannot be set to N while continuous merged update is active.
FRAMEBUFFER MERGE col,A - aborts the continuous updates
In addition deleting either the layerbuf or framebuffer will abort the automatic update as well
Basically, this gives you a full 2-layer graphics capability with the background layer in the F buffer and the top layer in the L buffer
Note: Of course using FRAMEBUFFER MERGE in continuous mode is incompatible with touch or SDcard on the same pins
Edited 2023-10-17 22:18 by matherp
Posted: 12:25pm 17 Oct 2023
This looks excellent. I wish I knew enough to be able to test it. Can you (or can anyone else) provide a simple example of how it would work?
Posted: 01:53pm 17 Oct 2023
Here is a quick demo
https://youtu.be/GH-_HAiiWx0
and the code
FRAMEBUFFER create 'create a framebuffer
FRAMEBUFFER layer ' and a layer buffer
FRAMEBUFFER write f 'set graphics output to the framebuffer
Load image "b:/mandelbrot" ' and load a picture
FRAMEBUFFER merge 0,R 'now start a continuous update for the screen on CPU2
FRAMEBUFFER write l We will leave the framebuffer alone and just write to the layer
i=100
j=100
  Do 'creat a random origin for a circle staying on the screen
     x=i+Rnd()*6-3
     y=j+Rnd()*6-3
  Loop While x<50 Or x>MM.HRes-50 Or y<50 Or y>MM.VRes-50
  FRAMEBUFFER sync 'sync to the framebuffer write to avoid artefacts
  Box i-51,j-51,102,102,,0,0 ' clear the previous image
  Circle x,y,50,5,,RGB(red),RGB(blue) 'write a new image
  i=x
  j=y
Loop
and an updated version of the firmware
PicoMite.zip
Update rate is 27FPS on an 8-bit parallel ILI9341 and just over 13FPS on an SPI ILI9341
Edited 2023-10-18 00:53 by matherp
Posted: 03:20pm 17 Oct 2023
Peter,
If you make a change like this, why not call framebuffer f for what it is: FRAMEBUFFER N .
Edited 2023-10-18 01:21 by Volhout
Posted: 03:35pm 17 Oct 2023
No: this is all additional functionality and everything can still be used exactly as before so N is the physical display, F is the framnebuffer and L is the layer buffer
One more update
PicoMite.zip
FRAMEBUFFER MERGE col, [,B/R/A] [,cycletimeMS]
The cycletime is how fast you want the updates to happen so if you want them every 100mS set cycletimeMS to 100. Defaults to 0 which runs as fast as the display can manage (75mSec ILI9341 SPI, 36mSec ILI9341 parallel)
NB: this command can only be used in a program and the automated updates are stopped on any program exit (Ctrl-C, error, END)
New command
FRAMEBUFFER SYNC
waits for the latest update to complete to allow drawing without tearing
Edited 2023-10-18 02:42 by matherp
karlelch
Posted: 04:41pm 17 Oct 2023
Hi Peter
Having similar functionality in those versions - where reasonable - would be great.
  Quote  This does slow very complex programs with many functions and subroutines by up to around 7% but performance is still the same as the VGA version
Could you please quantify “complex programs” and “many functions and subs”?
Thanks!
Posted: 04:47pm 17 Oct 2023
Solar Eclipse calc has 30 subs/3210 lines with considerable nesting and runs 7% slower
The VGA version has a layer capability. The Webmite cannot as too many time-critical interrupts
Bleep
Posted: 04:57pm 17 Oct 2023
Hi Peter,
I have just been experimenting with the above versions, looking good thanks, however I have found a bug, if you place a pause, of any length in the loop of your above program the program locks up. :-(
I'll avoid pauses for the moment. :-)
Regards, Kevin.
Bleep
Posted: 05:24pm 17 Oct 2023
Sorry, but also if I do the following with your example above.
I have had to change you're mandelbrot to a another bmp I did have.
My options are:
PicoMite MMBasic Version 5.07.08RC10
OPTION SYSTEM SPI GP6,GP3,GP4
OPTION COLOURCODE ON
OPTION LCDPANEL ILI9341, RLANDSCAPE,GP2,GP1,GP0
OPTION TOUCH GP5,GP7
OPTION SDCARD GP22
OPTION AUDIO GP20,GP21, ON PWM CHANNEL 2
do a reset, not power off.
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
> run
[4] Load image "b:/small" ' and load a picture
Error : SD Card not found
> B:
> run
22457.904
75.517
74.189
74.176
74.246
74.251
> run
Error : A hard error occurred in the low level disk I/O layer
At his point the screen goes white and I get a complete lock up.
Edited 2023-10-18 03:28 by Bleep
Posted: 07:20pm 17 Oct 2023
  matherp said  Here is a quick demo
Thanks for the example. I didn't have the mandelbrot.bmp file, so used Martin's Petskii Robots initial screen. I added code to change the colors randomly every second:
Dim integer fClr,bClr,b%(15)=(RGB(red), RGB(green), RGB(blue),0,0,0,0,0,0,0,0,0,0,0,0,0)
b%(5)=RGB(gold): b%(6)=RGB(magenta): b%(7)=RGB(brown): b%(8)=RGB(pink)
b%(9)=RGB(salmon): b%(10)=RGB(orange):b%(11)=RGB(grey):b%(12)=RGB(white)
b%(13)=RGB(lightgrey): b%(14)=RGB(beige): b%(15)=0 ' black
FRAMEBUFFER create
FRAMEBUFFER layer
FRAMEBUFFER write f
' Load image "b:/mandelbrot"
Load image "b:/petscii-intro"
FRAMEBUFFER write l
i=100
j=100
FG=RGB(red)
BG=RGB(blue)
   If Rnd()>.5 Then x=i+Rnd()*12-3 Else x=i-(Rnd()*12-3)
   If Rnd()>.5 Then y=j+Rnd()*12-3 Else y=j-(Rnd()*12-3)
 FRAMEBUFFER sync
 Box i-51,j-51,102,102,,0,0 :Circle x,y,50,5,,FG,BG
 i=x
 j=y
'  If Timer/1000 <> lastTime Then lastTime=time/1000: FG=RGB(b%(Rnd()*15)): BG=RGB(b%(Rnd()*15))
   lastTime=time/1000: fCLR=Rnd()*15: bClr=Rnd()*15: ' Print fClr;"/";bCLR;" ";
   FG=b%(fCLR): BG=b%(bCLR)
 EndIf
Loop
Youtube video: example for new framebuffer commands
petscii-intro.zip
EDIT: Running a second time after successfully running and terminating with Ctrl+C, I get the same error message as Bleep--with no lockup, but with drive B: "not found".
> RUN
> RUN
[9] Load image "b:/petscii-intro"
> files
A:/
  <DIR>  .
  <DIR>  ..
00:00 01-01-2000          4  bootcount
00:01 01-01-2000       1036  fr.bas
00:04 01-01-2000        360  frames_exp.bas
2 directories, 3 files, 622592 bytes free
> b:
> files
After power-cycling, I have drive B: back again.
Edited 2023-10-18 05:29 by lizby
Posted: 08:02am 18 Oct 2023
Thanks for the feedback - I'm pretty sure both issues are a stack overflow problem on the second processor (they have separate stacks). Will post an update later today when I've got to the bottom of it.
Posted: 10:24am 18 Oct 2023
I think this is more robust now. Please try and see how you get on
PicoMite.zip
Posted: 12:22pm 18 Oct 2023
  matherp said  I think this is more robust now.
Multiple runs with no problems now. This is cool--thanks.
