Forum Index : Microcontroller and PC projects : How many Erase / Rewrite cycles can I put my Pico's through?
| EDNEDN Guru Joined: 18/02/2023 Location: United StatesPosts: 306 |
Every time I edit a BASIC program on my Pico, it erases and rewrites it to the device. And the same thing happens every time I make a tweak to the MMBasic firmware. The device gets erased and rewritten. How long until I start to have problems? |
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2052 |
Around 100,000 so I wouldn't worry about wearing it out. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Just get a spare. Or two. :) At 4-writes per hour, 24 hours day, 365 days per year, that would work out at about three years minimum if there's no wear-levelling. That's for the flash, of course, there's no restriction on RAM. In real life you could probably expect at least three times that. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Wow! Thank You so much for the information.... I was trying to figure out and resolve as many bugs and problems as possible before I did an erase / rewrite cycle. I'm glad to know that isn't necessary. |
| Andy-g0poy Regular Member Joined: 07/03/2023 Location: United KingdomPosts: 85 |
If you are really concerned then there are versions of MMBASIC for the PC Windows and Linux (Linux) https://github.com/thwill1000/mmb4l (Windows) https://geoffg.net/WindowsMMBasic.html Obviously the IO parts of the pico ext will not be available, but if you are just sorting out standard routines then it's a useful testing setup. Andy |
