Local Time 20:55 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Umite Backpack 24 to 12 Hr Help
Mickanical
Posted: 10:38am 09 Oct 2023
Hi Folks
I'm trying to convert 24hr to 12 Hr on a Umite Backpack. Project Code attached.
Have added the following code from the manual after scouring the forum.
'As another example, let us say that you need a function to format time in the AM/PM 'format:
FUNCTION MyTime$(hours, minutes)
LOCAL h
h = hours
IF hours > 12 THEN h = h - 12
MyTime$ = STR$(h) + ":" + STR$(minutes)
IF hours <= 12 THEN
MyTime$ = MyTime$ + "AM"
ELSE
MyTime$ = MyTime$ + "PM"
ENDIF
END FUNCTION
I get this error but i'm unsure how to declare it.
RUN
[70] Text 150,45,Str$(MYTIME),CM,1,2,RGB(WHITE),RGB(BLACK)
Error: MYTIME not declared
Any guidance is much appreciated
Michael
SPRINKLER ON TOUCH V4 Rev 3 AM PM.zip
twofingers
Posted: 10:54am 09 Oct 2023
Hi Michael,
hmm, MYTIME <> MYTIME$ ?
Regards Michael
Please try:
Text 150,45,MYTIME$(hour, minute),CM,1,2,RGB(WHITE),RGB(BLACK)
There is more "bad" (less optimal) code:
SUB PLANTS
   PIN(PLANTSOL)=1     'Sol 3 on
   TEXT 160,100," WATERING PLANTS ",CM,1,2,rgb(BLACK),RGB(BLUE)
   Countdown=Plantsmin
   Gosub Count
   PIN(PLANTSOL)=0     ' Finished watering
   TEXT 160,100,"   PLANTS DONE     ",CM,1,2,rgb(WHITE),RGB(BLUE)
 end sub
Count:
 CountLoop:
 TEXT 160,250,STR$(CountDown),CM,1,2,RGB(WHITE),RGB(BLUE)
 pause 1*MINS
 Countdown=Countdown-1
 IF Countdown>0 then goto CountLoop
 endif
 end sub
I would prefer this
SUB PLANTS
   Countdown=Plantsmin
   Count_sub
end sub
Sub Count_sub
 do
   pause MINS
   inc Countdown-1 'oops, I think "INC" is not available for MicroMites
 loop while Countdown>0
end sub
... untested
Edited 2023-10-11 03:41 by twofingers
