Local Time 23:21 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit 5.0
palcal
Posted: 05:54am 09 Oct 2023
MM Edit 5.0
When I send a listing to the editor long lines are wrapping around then when I load the file into another MM there are numerous errors where one line is now two.
Is there a way to increase the line length in the editor ?
Posted: 06:23am 09 Oct 2023
If you are sending a listing from the 'mite to MMEdit, it is probably the 'mite that is doing the line wrapping.
I try and remember to set the 'mite console to a wide setting to reduce the chance of wrapping.
MMEdit can handle anything you are likely to throw at it and the later versions of MMCC also handle long lines.
A quick way to check a listing for unwanted wrapping is to set the column marker that puts a line at column 80 and scroll down the listing. Lines that come close need a closer look.
palcal
Posted: 07:57am 09 Oct 2023
I tried to set the column marker but could not see how. I have checked show column 80 and I'll set Option Display to 100,43 and see if that works.
Edited 2023-10-09 18:31 by palcal
