Forum Index : Microcontroller and PC projects : Updated the pico compiler
| gadgetjack Senior Member Joined: 15/07/2016 Location: United StatesPosts: 236 |
For Mixtel90 . They have an updated firmware for the board you designed for me that ran the little compiler. It can now have a usb keyboard connected to edit and save code right on the little lcd. This makes it a bit easier to write code for it. Its at the same site as before on github. I did translate the F key codes if you want it. Helps with edits. Jack |
Oh, yes - that was the little 4" square board with the ILI8341 and buttons, wasn't it? IIRC there's not much space on there for a PS/2 socket. :) Isn't the text rather small and screen scrolling slow for editing on that display? Mick Zilog Inside! nascom.info for Nascom & Gemini |
