Local Time 15:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/VGA/WEB V5.07.08 release candidates
     Page 1 of 18
Posted: 08:21am 19 Sep 2023
V5.07.08RC1
I think it is time to put V5.07.08 to bed so no more functional changes just fixes for any bugs found.
The big ticket things in V5.07.08 are UDP support for the WebMite, Mod file playback for all versions, H/W watchdog, support for regular expressions in the instr and linstr functions (particularly useful for web parsing), and a range of changes to help improve performance for games developers and for plotting data
Compared to V5.07.07, 08 has the following detail changes:
New functionality
WEB TCP SEND cb%, data%()
WEB TCP CLOSE cb%
OPTION UDP SERVER PORT n
WEB UDP INTERRUPT intname
WEB UDP SEND addr$, port, data$
OPTION WIFI SSID$, PASSWD$, [NAME$] [,IPADDRESS$, MASK$, GATEWAY$]
INSTR([start],text$, search$ [,size])
LIINSTR(text%(),search$ [,start] [,size]
PIO DMA TX now accepts 0 for the number of conversions when using a ringbuffer for continuous output
PIO DMA RX now accepts 0 for the number of conversions when using a ringbuffer for continuous input
ADC RUN array1%(),array2%()
OPTION MODBUFF ENABLE/DISABLE [sizeinK]
PLAY MODFILE fname$
PLAY MODSAMPLE sampleno, channelno [,volume]
WATCHDOG HW OFF
WATCHDOG HW nmSec
BITBANG WS2812 W, pin, nbr, value%[()]
OPTION WEB MESSAGES ON/OFF
Implements interlock to stop other ADC use while ADC DMA is running.
BLIT WRITE [#]b, x, y [,mode]
MM.INFO(ADC DMA)
MATH WINDOW in(),min, max, out(),[minfound, maxfound]
/* and */ commands for multiline comments
BLIT MEMORY address%, x, y[,col]
BLIT COMPRESSED address%, x, y[,col]
BLIT FRAMEBUFFER F/L/N, F/L/N, xfrom, yfrom, xto, yto, width, height [,col]
EDIT fname$
Bug Fixes
MM.INFO(OPTION ANGLE) returns an incorrect value. Fixed in V5.07.08b5
FORMAT$ function may not yield expected results (WebMite only). Waiting for SDK change
Minor bugs in CALL and MM.CMDLINE$. Fixed in V5.07.08b5
LOAD SPRITE requires exact spacing of the width,number,height fields. Fixed in V5.07.08b5.
Changing volume when PLAY TONE is playing the same on both channels causes one channel to disappear. Fixed in V5.07.08b5.
A TCP request while in the editor causes the WebMite to crash. Fixed in V5.07.08b5.
Memory leak in WEB MQTT PUBLISH. Fixed in V5.07.08b5.
EXECUTE command does not work at the command prompt. Fixed in V5.07.08b5.
CLS after NEW when a framebuffer is active can crash system. Fixed in V5.07.08b5.
Using EXECUTE in a program that has been AUTORUN crashes the system. Fixed in V5.07.08b5.
Bug in FRAMEBUFFER COPY to N. Fixed in V5.07.08b7
Bug in FRAMEBUFFER CLOSE. Fixed in V5.07.08b7
Race condition when PLAY TONE is used with defined time and a new tone is issued during the termination. Fixed in V5.07.08b8
Fixes various bugs in ADC use after ADC DMA conversions.
Fixes bug in PIN(TEMP) after another ADC channel is used.
Fixes bug in PIO assemble
Fixes bugs in BLIT WRITE when target overlaps the screen
Fixes bug in web transmit page when the size of included variables exceeds the size of the html file by a margin
atmega8
Posted: 10:42am 19 Sep 2023
Thank you Peter
carlschneider
Posted: 12:24pm 19 Sep 2023
Thanks for all your efforts Peter, much appreciated.
Cheers Carl
Retirement is tough on Hobbies without a day job
Posted: 01:36pm 19 Sep 2023
Amazing. What a terrific body of work.
Plasmamac
Posted: 05:15pm 19 Sep 2023
Thank you ,its great
Plasma
Posted: 05:17pm 19 Sep 2023
IanRogers
Posted: 05:56pm 19 Sep 2023
Aww!  I only just updated with b17.
Thanks anyway.
I'd give my left arm to be ambidextrous
carlschneider
Posted: 11:53pm 19 Sep 2023
Hi Peter
My understanding from previous comments made by others is that there were problems with the Tick's.
I also understand that this was addressed and resolved.
Could I trouble you to provide a brief synopsis of what the problem was/how it manifested?
I have a situation where the Tick’s appear to no longer interrupt after a period of working fine. Or are the Tick interrupts non latching and of short duration and could get lost in the priority order of the interrupt servicing routines at the core code level?
Cheers Carl
vegipete
Posted: 06:01am 20 Sep 2023
Working good so far. Great work!
Edited 2023-09-20 16:03 by vegipete
pwillard
Posted: 12:33pm 20 Sep 2023
Agreed.  I'm not having any issues.
Posted: 02:27pm 20 Sep 2023
@Peter,
In case we want to use the library to store tiles and sprites in CSUB, this is command line work. LIBRARY SAVE cannot be executed from withing a program, nor from a FLASH SLOT (tried it).
It would be nice to have a virgin pico, insert a SD card, and run a single program (without any command line typing) and the pico initializes the library.
Is there any way to pull this off ? MM.STARTUP ??
Or are we stuck with manual filling the library.
Posted: 07:07pm 20 Sep 2023
@Peter,
Using picomiteVGAV50708RC1
program memory on the VGA is 100k
I have a file size 80k on disk, that contains compressed tile data as CSUB (using your program to generate them).
When I load this file, I get "not enough memory" error.
In the editor, it feels the whole file is correctly in memory.
But when I do a library save, nothing gets in the library, and "memory" gives 0 byte in program memory.
tile1_csub.zip
EDIT: A file size 62k loads correctly.
stanleyella
Posted: 08:26pm 20 Sep 2023
I always reset the options cos thought they got erased when flashing new firmware but seems to remember??
option list
PicoMite MMBasic Version 5.07.08RC1
OPTION AUTORUN ON
OPTION CPUSPEED (KHz) 378000
OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13
OPTION TOUCH GP12,GP11
GUI CALIBRATE 0, 3888, 3842, -897, -655
OPTION SDCARD GP22
OPTION AUDIO GP0,GP1, ON PWM CHANNEL 0
Posted: 08:49pm 20 Sep 2023
  Quote  When I load this file, I get "not enough memory" error.
Yes: The CSUb ends up with two copies, the ascii and the binary. This is why csub/fonts etc. should be loaded into the library before the main program is loaded
disco4now
Posted: 10:27pm 20 Sep 2023
Volhout,
It is probably not exactly what you are after but this may gives some ideas for using programmed function keys to simplify saving the library.
Simple scripting MMbasic
Gerry
F4 H7FotSF4xGT
Bernie3D
Posted: 03:55am 21 Sep 2023
Thanks Peter for all.
Do you ever sleep?
Posted: 05:37am 21 Sep 2023
  disco4now said  Volhout,
Gerry
Thanks for the tip. I was aware of the function keys. They are helpfull with development, but this is not usefull for the game roll out.
At the moment this has to happen
Load "file1
Library save
Load "file2
Library save
Load "file3
Library save
Load "file4
Library save
Load "game
Run
Edited 2023-09-21 15:38 by Volhout
TheMonkeys
Posted: 05:54am 21 Sep 2023
🤔🤔🤔 Hmmm...
A little weirdness.
Since upgrading from V5.0707B11 to  V5.07.08RC1 this morning, I'm copping a watchdog every 36 minutes.
I re-uploaded the basic code, but no change. Have I missed something? On the third occasion, I was watching. Both my heartbeats froze, then after my 20 second timeout, it (webmite) re-booted, as expected.
from my logfile:
21-09-2023 started@10:04:15 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10 (***installed V5.07.08RC1)
10:04:15 dat/activity.log: 3 rotates
10:04:57 0: Rename "update.bas" As ".trash/update.bas"
10:05:15 0: Kill ".trash/update.bas"
10:14:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011
21-09-2023 started@10:17:09 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10
10:29:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011
21-09-2023 dogged@10:38:40 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10
10:39:58 #Config: ts:3 sp:23 dog:20 debug:11
10:44:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011
10:59:10 Schedule: heater on [setHeater(2)]
10:59:52 State: tmax=31.3 tmin=28 ts:3 tstat=30 debug=&B1011
11:02:10 Schedule: heater off [setHeater(1)]
11:05:10 Schedule: heater auto [setHeater()]
21-09-2023 dogged@11:14:49 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 10:10
11:14:52 State: tmax=31.3 tmin=28 ts:3 tstat=30 debug=&B11
11:20:52 #Config: ts:3 sp:23 dog:20 debug:3
11:21:04 #Config: ts:3 sp:23 dog:20 debug:11
11:29:52 State: tmax=31.3 tmin=28 ts:3 tstat=23 debug=&B1011
21-09-2023 started@11:38:28 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 (***small edit to init code)
11:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
11:45:36 0: Rename "update.bas" As ".trash/update.bas"
11:45:52 0: Kill ".trash/update.bas"
21-09-2023 dogged@11:50:55 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40
11:54:44 #Config: ts:3 sp:23 dog:20 debug:11
11:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
12:07:21 2:indexing dom
12:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
21-09-2023 dogged@12:27:04 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40
12:27:47 #Config: ts:3 sp:23 dog:20 debug:11
12:29:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
12:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
12:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
21-09-2023 dogged@13:03:12 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 (***froze@13:02:45)
13:05:54 #Config: ts:3 sp:23 dog:20 debug:11
13:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
13:29:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
21-09-2023 dogged@13:39:18 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40
13:43:57 #Config: ts:3 sp:23 dog:20 debug:11
13:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
13:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
14:05:10 rembeg: 14:05 remend: 15:05 remdur: 60
14:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 remend:905 remdur:60
21-09-2023 dogged@14:15:27 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40
14:18:26 #Config: ts:3 sp:23 dog:20 debug:11
14:29:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 remend:905 remdur:60
14:44:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011 remend:905 remdur:60
21-09-2023 dogged@14:51:35 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40 (***froze@14:51:09)
14:59:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B11 remend:905 remdur:60
15:02:12 #Config: ts:3 sp:23 dog:20 debug:11
15:14:52 State: tmax:31.3 tmin:28 ts:3 tstat:23 debug:&B1011
21-09-2023 started@15:28:40 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40(***froze@15:27:17)
***froze completely - USB restart
21-09-2023 started@15:30:22 Legion WebmiteOmnibusWebserver 12R2.6 21 Sep 2023 11:40
Any suggestions?
Cheers,
Chris
Posted: 06:18am 21 Sep 2023
If no one comes up with anything better...
As you have upgraded a full version number it may be worth saving Options, Program, Flash slots and A: then applying Clear_flash.uf2 and reloading it all.
TheMonkeys
Posted: 06:51am 21 Sep 2023
Hi Phil,
Oops, my miss-type. It was V5.0708B11
Cheers,
Chris.
     Page 1 of 18
