Local Time 21:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pi-Pico Picomite PIN42(GP24) ??
Hansaplast
Posted: 09:44am 13 Sep 2023
The following message by using OPTION SDCARD
> OPTION SDCARD GP24
Error : Pin 42/GP24 is in use
the same happen with
> OPTION SDCARD GP23
Error : Pin 41/GP23 is in use
This can't be, as PIN 42 of the Pi-Pico is VCC (IOVDD) and GP24 is PIN 36
or I'm wrong??
Edited 2023-09-13 19:52 by Hansaplast
circuit
Posted: 10:04am 13 Sep 2023
  Hansaplast said  The following message by using OPTION SDCARD
> OPTION SDCARD GP24
> OPTION SDCARD GP23
or I'm wrong??
See the Picomite manual page 10;
"On the Raspberry Pi Pico these pins are used for internal functions as follows;
Pin 42 or GP24 is a digital input which is high when VBUS is present".
Hansaplast
Posted: 10:11am 13 Sep 2023
Yes, I saw
 Pin 41 or GP23 is a digital output set to the value of OPTION POWER. (ON=PWM, OFF=PFM).
 Pin 42 or GP24 is a digital input, which is high when VBUS is present.
 Pin 43 or GP25 is also PWM4B. It is an output connected to the on-board LED.
 Pin 44 or GP29 is also ADC3 which is an analog input reading ⅓ of VSYS.
Is there any way to make it working?, as I use the Pi-Pico chip on my own PCB with all ports.
Posted: 10:43am 13 Sep 2023
Just set them off before use
SETPIN GP23,OFF
etc.
