Local Time 20:41 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Time offset between two pins
     Page 1 of 3
Frank N. Furter
Posted: 11:43am 08 Sep 2023
Hello to all,
I would like to use a PicoMite to measure the amount of time between the low/high transition of two pins. So a timer would have to be started when the first pin goes high and stopped again when the second pin also switches from low to high.
What is the easiest way to program this? I don't know how to solve this with an interrupt...
(It can also happen that the second pin is already High - then it would have to wait until it becomes High again...)
To poll the inputs cyclically would be one possibility - with interrupt it would be more accurate?
The task is to determine the time offset of the zero crossings of two 50Hz sinusoids, which were previously transformed into square wave voltages by two comparators.
Any programming suggestions would be very welcome!
THANKS!!!
Frank
Posted: 12:20pm 08 Sep 2023
What is the accuracy you need ?
Of coarse the PIO is the most accurate way, or Peter's CSUB.
But if accuracy is not needed to be high (i.e. just to check if a 3 phase syste is left- or right-rotating) then you could do interrupts
one interrupt for each zero crossing input pin
each interrupt just stores the TIMER into a variable
the main level only calculates the difference ...
P.S. with an extra logic gate you can convert the 2 zero crossing signals to a single pulse. Then a single pin could measure pulse width.
P.P.S. Peters CSUB
Option explicit
Option default none
Interrupt myint 'set up an interrupt that can be triggered by the CSUB
SetPin gp6,cin,3 'set pin 9 (GP6) to cause a H/W interrupt on both edges
Dim a%(100) 'array to receive the timestamps
Dim b%=100 'maximum number of transitions to receive
Dim c%=20000000 'timeout of the CSUB in microseconds
log a%(),b%,c% 'initialise the logging
Do :Loop  'loop continuously
Sub myint 'subroutine that is triggered when the non-blocking CSUB terminates
local integer i
Do While a%(i) 'read all valid data
  Print i,a%(i) 'print it out
  Inc i 'increment the loop counter
Loop
Print "end"
Pause 200
End  'terminate the program
End Sub
' This CSUB logs activity on GP6, each transition of the pin is
' logged to the nearest microsecond. The timestamp is positive for positive
' going transitions and negated for negative going ones
' The parameters are:
' an integer array to hold the timestamps
' an integer with the number of samples to take (the array must be at least this big)
' an integer giving a timeout in microseconds for the CSUB to terminate
' if the number of sample requested is not reached
' when either the timeout occurs or the number of samples is reached the
' CSUB triggers an interrupt to let the Basic program know
CSUB LOG
00000041
'check_timer
B082B580 4B10AF00 3320681B 4B0F607B 4798681B 681A687B 4299685B D10ED803
D8004290 4B0AE00B 2200681B 4B09601A 2200681B 4B08601A 2201681B 46C0601A
B00246BD 46C0BD80 1000038C 100003AC 10000388 100003C8 100003D0
'intprog
B085B590 4B22AF00 60FB681B 681B4B20 60BB3310 681B68FB 68BB607B 1E5A681B
601A68BB 681B68BB DC0B2B00 681B4B19 601A2200 681B4B18 601A2200 681B4B17
601A2201 681B4B16 47982009 D0081E03 681B4B14 00024798 6879000B 604B600A
4B10E00C 4798681B 000B0002 42502100 687C4199 000B0002 60636022 681B68FB
001A3308 601A68FB 46BD46C0 BD90B005 1000038C 10000388 100003C8 100003D0
1000032C 100003AC
'main
B088B580 60F8AF00 607A60B9 681B4B16 447A4A16 4B16601A 4A16681B 601A447A
681B4B15 4B1461FB 3310681B 4B1261BB 3320681B 68FA617B 601A69FB 681A68BB
69BB685B 4B0D601A 4798681B 000B0002 68086879 18126849 6979414B 604B600A
46BD46C0 BD80B008 100003C8 FFFFFF43 10000388 FFFFFEDD 1000038C 100003AC
End CSUB
Edited 2023-09-08 22:25 by Volhout
Posted: 12:29pm 08 Sep 2023
Untested but may be worth a try.
 Do : loop until pin(1) And pin(2) 'Wait for both to be high
 Do while pin(1) And pin(2) : loop 'Wait for pin2 to fall
 if pin(1) And (Not pin(2))
  timer = 0 : Do while pin(1) And (Not pin(2)) : loop : T = timer
  Print "Time between falling edges  ";T;"mS"
 EndIf
Loop
Edited 2023-09-08 22:36 by phil99
Frank N. Furter
Posted: 12:43pm 08 Sep 2023
@Volhout:
The two curves represent the current and voltage.
I need the current/phase offset to see if (and how much) current is being consumed or generated.
I am not yet clear about the required resolution. I think 0.1 to 0.5 milliseconds should be enough...
Does this CSUB really work on a PicoMite?
  Quote  P.S. with an extra logic gate you can convert the 2 zero crossing signals to a single pulse. Then a single pin could measure pulse width.
That's a good idea!
@phill99:
Your solution looks quite interesting too!
THANKS!
Frank
Posted: 05:27pm 08 Sep 2023
Hi frank,
The csub may need re-compiling for the latest firmware.
If I read correct you have analog voltage and analog current from the adc.
Assuming you have multiple samples per 50hz sine wave.
Why not multiply the associated samples? Gives you true watts.
Rms the voltage
Rms the current
Multiply these gives VA
Cos phi is watt/VA
This does not give you the actual inductive/capacitive value, for this you would need an additional step. But you do not need any additional hardware. Just the data you already have in the memory.
P.S. you can find positive/negative angle by by finding the first zero crossing in voltage array, and the first in current array. That will tell you pos or neg. angle.
Edited 2023-09-09 04:09 by Volhout
Bernie3D
Posted: 02:40am 09 Sep 2023
@Volhout
I can confirm that CSUB fails on Picomite v50707b18 and beyond.
It was possibly the update on SDK v1.5, which occurred on that release.
I like that CSUB for decoding a pulse trains like Manchester code, which are used in protocols like LTC (Linear TimeCode). It would be a nice Function, something like PULSIN.
Frank N. Furter
Posted: 07:17am 11 Sep 2023
Hi Volhout,
My problem is that the voltage curve is distorted, because I can tap the voltage only after a transformer.
Don't you think it would be better to detect the zero crossing and then superimpose an ideal sine wave over it?
This is what my measurement currently looks like:
Blue is the mains voltage (after the transformer) and raised into the positive range (1V52), red is the current waveform (here from a 1800W hairdryer).
How would you evaluate these measurement results now???
THANKS!
Frank
Edited 2023-09-11 17:20 by Frank N. Furter
Posted: 08:02am 11 Sep 2023
You can never be sure of the wave shape from the mains supply. It varies with the load at any one time as well as with whatever transformers are feeding your site. It's always distorted to some extent.
Because of power factor there is rarely any relation between load voltage and load current unless the load is purely resistance heating (no motors).
Basically, if you want reasonable accuracy work with either voltage at the load terminals or current into the load but not both unless you really *have* to calculate power into the load. Try to avoid that if you can, for that way madness lies. :)
The "proper" way to do it is to use a True Watts Transducer. They are a current transformer and voltage monitor combined and produce a control voltage or current that is proportional to the load Watts, no matter what the power factor is. They cost rather a lot though, being industrial gear.
Posted: 08:32am 11 Sep 2023
This version of CSub LOG may work.
CSub LOG update
  disco4now said  The LOG CSUB compiled with the new header file as required from V5.07.05 Beta13 onwards.
The mains waveform shown above is too distorted. Mains distortion rarely exceeds 5%. Put a resistive load on the transformer output, 10% of it's rated power will do then see if it looks better.
Edited 2023-09-11 18:39 by phil99
Frank N. Furter
Posted: 08:43am 11 Sep 2023
@Mixtel90:
Oh, I think I can be sure of that! Nothing more than the measuring unit is connected to the transformer - i.e. without any additional load.
I got the idea from here!
Frank
Posted: 09:08am 11 Sep 2023
I also started out with using a transformer to isolate mains voltage.
But the transformer showed similar distortion as yours.
I tried (resistive) loading the transformer, but until the load was really close the the transformer rating (several Watt) it remained distorted, and worse, it showed phase lag.
I settled on this circuit
mains analyzer
The 10meg resistors are high voltage resistors. They isolate mains voltage from your picomite. 10 meg is sufficiently high to have minimal leakage current (it is safe to touch).
Note that I used 4 resistor 75k (you can also use 68k) so they are best matched. Preferably 1% or better parts, preferably also get 10 meg 1% parts.
Edited 2023-09-11 19:17 by Volhout
Posted: 09:59am 11 Sep 2023
I get reasonable waveforms using a small toriodal core transformer lightly loaded.
With your two waveforms.
subtract the mean to get them centred about zero.
multiply the two arrays element by element to get instantaneous power.
the mean will be positive or negative depending on direction.
I will try and put up some code and resulting graphs tomorrow some time.
I am presently developing a power monitor so the timing is fortunate.
Posted: 10:36am 11 Sep 2023
All VTs introduce a measure of phase error simply because the windings are inductive and there is capacitive coupling between them. You can reduce the errors by paying more, strangely enough. :)
Frank N. Furter
Posted: 11:14am 11 Sep 2023
@Volhout:
Your solution looks good - unfortunately I need mandatory galvanic isolation!
@TassyJim:
Can you tell me which transformer you used for this? I would be very interested in the exact type...
@Mixtel90:
With a constant load, the phase shift should also be constant and can therefore be calculated out...
I have now tried reducing the load on my transformer - the curve now looks better. However, the amplitude (also because of the downstream low-pass) is now much too low and everything would have to be adjusted again...
Frank
Posted: 11:28am 11 Sep 2023
  Frank N. Furter said  the amplitude (also because of the downstream low-pass) is now much too low and everything would have to be adjusted again...
Frank
That is okay, since it is a 1x execsize. As long as it represents the input waveform that should be fine.
Maybe it is not usefull, but if you want some reading:
energy meter.zip
This is how they achieve a relatively good and simple energy meter using onboard ADC's inside a microcontroller. But they hard connect the micro to the Neutral of the mains network, and opto isolate the output. It was nice reading though.
And yes, you are correct , the high impedance resistors are no galvanic isolation. Did you know these resistors where in every switchmode power supply up to 10 years ago the meet the requirement that after pulling the power plug, the pins should be discharged withing 2 seconds. So Y-capacitors where discharged using these resistors.
Edited 2023-09-11 21:29 by Volhout
Posted: 11:58am 11 Sep 2023
  Quote  unfortunately I need mandatory galvanic isolation!
What about using analogue opto isolators. I've used HCNR201 in the past and they work well
Frank N. Furter
Posted: 12:32pm 11 Sep 2023
@Volhout:
Thank you for your interesting document.
@matherp:
How would you set that up then?
Frank
Posted: 12:49pm 11 Sep 2023
  Quote  How would you set that up then?
On the non-isolated side scale the incoming mains to suit the opto
Then pass that through the opto and use the adc on the isolated side to detect the zero
Posted: 12:50pm 11 Sep 2023
@Jim, Frank,
I was amazed to see that you can use a common mode choke (ferrite material, not iron core) to measure mains voltage. The trick is to run it really low current, since it represents a really low impedance, and saturates easy. And terminate it in a virtual ground or other low impedance. To be usefull you need a common mode choke with a lot of turns on it.
using common mode choke
I just tried it with a 33mH commercial choke, and it actually works.
When you drive the common mode choke core too hard, it shows similar distortion as Frank's waveform. Maybe this is something Frank can try as well. Just put a lower voltage at the input of the transformer (33k/33k voltage divider so you have 115V to drive the transformer).
Never too old to learn...
Edited 2023-09-11 22:54 by Volhout
Posted: 02:37pm 11 Sep 2023
Simulation shows that something like this should work to measure mains voltage. I will try to prototype (build actual circuit) tomorrow.
     Page 1 of 3
