Local Time 21:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Nucleo-H743ZI2 back in stock at good price
Posted: 10:45am 07 Sep 2023
The Nucleo-H743ZI2 is the target  board for the ArmmiteH7 and I produced a comprehensive backpack for it - see here. The gerbers for the final version of the backpack are on page 3 (V1.3).
Now that Gerry is looking after the Armmite code I'm sure we will see new releases coming and the Nucleo together with the backpack make a hugely powerful combination
Looks like the chip shortage is finally coming to an end
Edited 2023-09-07 23:13 by matherp
Posted: 04:47am 08 Sep 2023
Yes, I noted that the PIC32MX470 series chips that the MM+ is built around, are now back in stock at Microchip Direct, in many thousand quantities.  BOTH the 64-pin and 100-pin versions - more then 10,000 chips of each in stock now.
I had managed to keep a couple of both of those in stock here, but they were STRICTLY as backup chips if I had a system failure.  I didn't dare use them in any new designs, in case I needed them to get something up and running again!
Now that the 470's are available again, I have ordered some more so I can start to think about MM+ designs again now.
KeepIS
Posted: 05:47am 08 Sep 2023
Thanks, I've been hoping the H7 had not been forgotten, I look forward to any improvements or additions to this great combo.
BTW: Four x V2 development boards arrived about 8 weeks ago. When I odored them I knew the wait time before production was due to restart was well over 6 months
disco4now
Posted: 06:15am 08 Sep 2023
Hi Mike,
I think I have fixed the issue where you had to load the old version before the new version  would run on a new ZI2 , but I can't prove it for sure until someone tries on a new virgin board. So if you still have any in their virgin state can you hold off programing them until I release a new beta for the H7. Should not be too long, just want to finish the F4 first.
Gerry
F4 H7FotSF4xGT
Posted: 07:17am 08 Sep 2023
Gerry,
I have a ZI2 board still in its package as well as one on one of Peter's backpack.
I will keep the clean one handy for testing your next release.
It is old stock so not likely to be the same revision as current ones.
disco4now
Posted: 08:12am 08 Sep 2023
Thanks Jim,
I am suspicious its just not using the latest ZI2s, its actually just using the current latest software on any virgin board, so yours will be a good test.
F4 H7FotSF4xGT
KeepIS
Posted: 09:47am 08 Sep 2023
  disco4now said   So if you still have any in their virgin state can you hold off programing them until I release a new beta for the H7. Should not be too long, just want to finish the F4 first
Hi Gerry, only one board unpacked at the moment, looks like you will have a few of us who can test for that part of the problem, also have a few backpacks and the 9" LCD converter boards.
Edited 2023-09-08 19:48 by KeepIS
