Local Time 21:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Miximite 2 firmware compatibility with other stm32 M7?
ice2642
Posted: 11:34am 30 Aug 2023
Hello,
I would like to know about the compatibility of the STM32H750VBT6, STM32H723VGT6
withe the STM32H742IIT6
For use the 50VBT6 or 23VGT6 instead the 42IIT6 to build a board what changes I can expect?
I am asking because I found this 2 demo boards much more cheap than the used in original project.
Thank you in advance.
Best regards,
MMBasic 5.0707 on PicoMite VGA
Posted: 11:55am 30 Aug 2023
IIRC STM do a Chip Selection pdf file, with abbreviated specs for the range (and there's a lot of them). I'd advise you to hunt that down first. Even then, you need to know if the demo board has enough external flash to be usable.
I'd not like to guess on this as there are too many variables.
Posted: 11:58am 30 Aug 2023
Won't work at all on the 750 as very little flash memory hence cheap
won't work on the other 2 as different (less) RAM
ice2642
Posted: 02:02pm 30 Aug 2023
  matherp said  Won't work at all on the 750 as very little flash memory hence cheap
Thank you!
Best regards,
ice2642
Posted: 02:05pm 30 Aug 2023
  Mixtel90 said  IIRC STM do a Chip Selection pdf file, with abbreviated specs for the range (and there's a lot of them). I'd advise you to hunt that down first. Even then, you need to know if the demo board has enough external flash to be usable.
Thank you!
Best regards,
Edited 2023-08-31 00:08 by ice2642
ice2642
Posted: 11:35am 02 Sep 2023
This board
The option STM32H743VIT6
It is VIT6, not VIIT6, have much diferences? this board will work?
Posted: 11:54am 02 Sep 2023
Link does nothing, sorry.
Posted: 12:05pm 02 Sep 2023
Searching on aliexpress for the item number in the malformed link shows this
This is an H7 board.
Posted: 12:11pm 02 Sep 2023
  ice2642 said  It is VIT6, not VIIT6, have much diferences?
There's no VIIT6.
There's IIT6 which I believe you need.
You can read ST's site about the chips :)
VIT6 100 pins, IIT6 176 pins.
Maybe it would work? Check the same overall flash & RAM are present and all I/Os needed. Seems unlikely with 76 pins fewer and cheaper!
Edited 2023-09-02 22:12 by JohnS
Posted: 12:19pm 02 Sep 2023
The H743 board should run the ArmmiteH7 firmware but no guarantees on things like SDcard, depends on which pins they are using compared to the NucleoH743 which is the target board for the ArmmiteH7. It won't/can't run the CMM2 firmware. As stated above the H750 board is completely useless
Edited 2023-09-02 22:21 by matherp
Posted: 12:20pm 02 Sep 2023
I'm not sure I've seen such a breadboard-hostile module since the original CMM2 one. :)
Without a circuit diagram, and considering that there may be VAT on those prices, I'll not even consider it.
Edited 2023-09-02 22:26 by Mixtel90
disco4now
Posted: 12:39pm 02 Sep 2023
This seems to be the link.
STM32H743VIT6
I have recently purchased another one of these. They all say they are the 400MHz chip but both I have received are the newer 480MHz chip. All the Ali vendors seem to be using the same add that obviously never gets updated.
And the sort of good news. In Jan 2022 Peter gave me a copy of the source for the ARMmiteH7 so I could try to include support for that particular board. I now have a single binary for the ArmmiteH7 that supports both the original 144 pin Nucleo board and this particular 100 pin STM32H743VIT6 board.
Once I have some confidence that the new release of the ArmmiteF407 is OK I will release and updated ArmmiteH743 binary that will support this board.
A extract from the pending manual.
The MMBasic firmware will also run on the STM32H743VIT6 100 pin version of the H7 chip. These 100 pin
boards have been tested:
 STM32H743VIT6 from WeAct Studio (no longer available)
 STM32H743VIT6 from DevEBox.
A single MMBasic firmware now supports both the 144 pin Nucleo board and the 100 pin WeAct Studio and DevEBox boards. The firmware can read the package information from the chip and determine the number of pins. It also reads the RevId on the chip and determines the CPU Speed to be 400MHz or 480MHz.
Within MMBasic MM.INFO(NRPINS) will return 100 or 144 to report the number of pins.
MM.INFO$(CPUREVID) will return “1003” for the chips with 400MHz CPU and “2003” for the chips with a
480MHz CPU.
Constraints with 100 pin STM32H743 boards
Due to the reduced number of pins available the following restrictions apply to the 100pin boards.
 The CAMERA command and MOVEMENT() function are not supported.
 The high speed count pin is not available.
 SPI3 is not supported.
The following restrictions are due to functions sharing pins, so they are mutually exclusive.
 PWM 2D and COM2 RX share pin 25 so only one is available at any time.
 SPI2 shares pins 42,43 and 44 with the SSD1963_x_16 parallel LCDPANELs so is not available if one
is configured. The SSD1963_5 to SSD1963_8 only use 8 bits, so SPI2 is available when they are
configured. Any buffered driver will use 16 bit s and these make SPI2 unavailable when configured.
Gerry
P.S. It wont run with the current ArmmiteH7 software as these boards have a 25MHz clock and current software expects 8MHz. The pending release can handle the 25MHz clock for the 100 pin board.
Edited 2023-09-02 22:44 by disco4now
F4 H7FotSF4xGT
Posted: 12:49pm 02 Sep 2023
Way to go, Gerry, should suit some people!
disco4now
Posted: 01:13pm 02 Sep 2023
The STM32H743VIT6 backpack.
F4 H7FotSF4xGT
Posted: 01:28pm 02 Sep 2023
It might be an idea to point out that this is for the 743 (i.e. more expensive) option, NOT the 750 version which the AE link seems to want to go to. The 750 is no good for this.
morgs67
Posted: 01:44pm 02 Sep 2023
@ice2642 link:
https://pt.aliexpress.com/item/1005005415869986.html?spm=a2g0o.cart.0.0.4e407f06H6JFWQ&mp=1&gatewayAdapt=glo2bra
You can select one or the other.
Tony M
ice2642
Posted: 01:24am 05 Sep 2023
Thank you all!
It was the link :) I do not know wat happens when I post the link.
I will buy the option STM32H743VIT6
Best regards,
Edited 2023-09-05 11:25 by ice2642
